Question about Brother XL-5130 Mechanical Sewing Machine
Top threaded needle will not grab bobbin thread so I can begin sewing.
  • Brother Master
  • 7,365 Answers
You might check your needle to see if it's bent
check in the bobbin area for any lint or loose threads
make sure there is a bobbin tail at least 2 to 4 inches long
hold the top thread tail ( at least 2-3 inch tail) as the needle goes down
to pick up the bobbin thread
Posted on Aug 04, 2010
How do I get my Elna 7000 to sew as when I thread the needle and start sewing - the thread is somehow pulled out of the needle?
If you haven't already, install a brand new needle. Be sure to use good quality thread--no old stuff or bargain bin variety.
Remove all the thread from the machine.
Raise the needle until it is at the highest point it will reach before it begins to lower.
RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Pull at least 5 inches of thread tail through the needle.
Check that the bobbin is installed correctly.
Set the upper tension to somewhere around the midway point between high & low number.
Pull the bobbin thread to the top of the fabric:
How and Why to Bring up the Bobbin Thread
When you begin to stitch, gently hold both thread tails with your left hand and begin stitching slowly to start.
Why does my thread keep pulling out of needle
Tilly and the Buttons Five Common Sewing Machine Mistakes How to Fix Them
Aug 17, 2016 | Elna Sewing Machines
I can't get my needle to grab my bobbin thread
Always--install a brand new needle. A bent/dull/damaged needle may not pick up the bobbin thread.
Remove the thread from the machine. Always Raise The Presser Foot and rethread from the beginning. Make sure the thread seats completely in the tension disk and the thread path is correct.
Test your machine. If it still fails to pick up the bobbin thread, then your machine may have a timing issue (the needle is arriving at the bobbin at the wrong time in order to intercept with the bobbin thread).
There are many web sites and videos explaining sewing machine timing. Or, you can take it for service.
Jul 17, 2016 | Sewing Machines
Thread keeps coming out of needle when sewing
When you start sewing, make sure the thread is long enough so the machine does not pull the loose end down into the bobbin casing. It is best to drawn both threads (bobbin and top thread) up through the pressure plate before you place the fabric under the pressure foot.
Mar 23, 2016 | Sewing Machines
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
Keeping the thread in needle when you begin to sew
after threading the needle pull about 6" of thread out the back under the press foot
that way the thread is jammed under the foot and is held in place for the next thread
bobbin thread should also be out the back
when you have finished sewing then lift the foot and move the material sewed about 6"" away from the foot before cutting the threads
Nov 03, 2015 | Sewing Machines
My bobbin thread won't come up with the needle. so, I can't sew. how do I fix it
First, make sure the needle is installed correctly. Then when you thread through the needle, it should go through the hole so that the thread basically lies inside the groove that runs down the side of the needle. These two steps are critical to being able to pick up the thread properly!! Typically the thread feeds from the left side or some from the front.
Secondly, make sure the bobbin is loaded correctly and firmly attached in place. The thread should just hang off the outside of the bobbin.
Hold onto the upper thread and manually turn the machine through the start of a cycle. When the needle goes into the top plate and down toward the bobbin, a hook should grab the top thread, rotate it about straight down (6 o'clock position) and then release it to grab the bobbin thread. Continue slowly turning the machine manually until you see (hopefully) the thread from the bobbin. Use something thin to pull both threads to the rear, under the foot, and all should be good. When you first start to sew, you might need to hold onto the top thread so it is not pulled out of the needle.
My guess is if you have done all the above, you could have a timing problem that needs to be adjusted at a repair shop.
Mar 08, 2014 | Singer Sewing Machines
My needle won't grab the bobbin thread but if I put some fabric in and start to sew the bobbin thread comes through. However, the bottom thread is all bunched up and causes the machine to jam.
the looping on the underside sounds like a needle thread tension problem. 1st off check top (needle) threading then turn machine by hand to pick up bobbin thread
Jan 02, 2014 | New Home HF-106
My needle does not pick up the bobbin thread. I double checked that I threaded the needle correctly and the bobbin seems to be in the right position. The needle doesn't look like it's making contact with...
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Sep 07, 2010 | Euro-Pro Shark 60 - 384
Needle won't grab thread from bobbin
Sometimes you have inserted the needle wrong, make sure that the needle faces the rear, if that is not it, try a new needle. Make sure that you have threaded the bobbin right, by your manual, and have at least a 6 inch tail, hold your top thread and move your handwheel towards you, not away from you and it will grab the thread. If any questions go to euro-pro.com
Sep 06, 2010 | Euro-Pro 9130 Sewing Machine
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
167 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
