Wet clothes however the soap did not dispense. Was going for about 30mins
  • jeanette244 Aug 03, 2010
    how can you open the door as it is a front loader?
  • 11,896 Answers
Check the tube that goes to the soap tray. It may be plugged or have a buildup of dried soap. If the hose is clear, follow the hose to the pump. Make sure pump is getting power with a voltmeter, if it is, test the pump itself with an ohmmeter.
Posted on Aug 04, 2010
  • 5,081 Answers
The washer can shake (some time very much) on the spin cycle (with a clothes inside) if it's out of balance. In such case it'll never go on full speed.
If it happens, you have to open the lid and redistribute the load.
Even the motor has two speeds, there is no separate speed switch on the control panel and you not able to choose the high speed for any cycle.
It will spin on the high speed only when the "regular" cycle used.
All other cycles will provide only low speed for the spin.
Also if there is too much suds, the washer will never drain completely.
You probably have a worn clutch and bad brake shoes, or something in the tub.
Shine a bright lite in the tub and look for something. If ok, pull the outer cover of the washer and pull the pump and motor out. Turn the coupler clockwise till the spin basket starts to turn. If very hard to turn the coupler, you have dragging brake shoes or a bad lint filter under the spin basket.
Posted on Aug 03, 2010
The soap dispenser only closes after several tries. At the end of the cycle, the soap is wet and stuck in the open dispenser
May want to try liquid detergent instead. Sometimes using too much detergent will prevent the dispenser from opening and then the soap turns into a wet glob in the dispenser.
Mar 15, 2016 | Dishwashers
Wet dishwashing soap
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Feb 27, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Can i adjust the water level on my Duet?
Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wet clothes, water in soap dispenser
Next check your drain, where the hose goes in behind, snake this out. And dont shove the hose in too deep, into the standpipe that is.
If this helps, rate me please.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
