Question about D-Link Computers & Internet
I lose my internet connection and at the same time my VOIP (I use a Linksys Phone Adapter PAP2 for VOIP) for a few seconds up to a minute, quite often. Comcast indicated that it isn't a problem on their end. I know exactly when my internet connection is lost and obviously when my calls are dropped. I use a D Link Ethernet Broadband Router D1-604. Thanks - I am at a loss
    Guru:
  • 528 Answers
Hi. were you able to test the connection. i advised you to bypass the router. Any feedback?
Posted on Aug 04, 2010
I have comcast cisco cable that is working fine but when I hook up vonage I get no internet why?
More than likely you need to enable split tunneling on vpn settings in router. If Vonage uses a vpn tunnel like other VOIP services do, then it is probably encrypting all traffic on your Internet/WAN interface. With split tunneling enabled it will only encrypt traffic to and from Vonage. I'm making a few assumptions here, but it should be worth a check.
Jul 23, 2014 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Password recovery on PAP2
There is a hard reset that can be done via the phone IVR. Connect an analog phone to the RJ-11 port on the PAP2 and pick up the handset, where you will hear dialtone. Press * (4) times and you will be told you are entering the configuration menu. Press 7 3 7 3 8 + # and you will be asked to enter 1 to confirm. Congratulations, you factory-defaulted your PAP2, the adapter will restart and you can log in with the default user name 'admin' with no password.
Mar 06, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Hello, I have a Linksys PAP2-VN VoIP adapter from Verizon Voicewing which you know is now defunct. I cannot access the web setup utility because it requires a password that was set up by Verizon and I...
HelloThe Password/user name will provides you by Verizon, try admin:admin
Here is a list of the most prominent VoIP services providers of this type but better service:
1. Vonage 2. Lingo 3. Voip.com 4. BroadVoice 5. Packet8 6. ViaTalk 7. AT&T CallVantage
Hope it helps, if so do rate the solution Good Luck
Dec 28, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linsys voip internet phone adepter PAP2T ip address
pulg phone pin in pap2 device phone1 pin then give internet connection to pap2 then dial from the phone *110# then u can here ip from pap2
Nov 11, 2009 | Linksys Computers & Internet
Hello,I have connected a linksys voip
Hello dandashi77,
I am using a Panasonic DECT 6.0 Series cordless phone. However, the VIATalk.com VOIP Services uses a LinkSys PAP2 adapter which can work with any type of phone. A Broadband connection is required to use the VIATalk.com VOIP service. Setup is very simple and the instructions areeasy to follow. Just a few simple things to do.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Connect my phone adapter
You need to register/subscribe to a VOIP provider first like Vonage and the likes. Then you need to register through your VOIP provider the phone ports of your router. ISP is different from VOIP.
Oct 24, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Computers & Internet Logo
95 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
