Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Picture out of alignment
I'm know somebody who has a 2003 Mitsubishi wt-42311 42" rear projection TV that they are selling for $300. During the move from Cali >NY the top of the cabinet was damaged. It looks like the movers stacked boxes on top of one corner of the TV and it was squished a bit. The actual damage to the cabinet is minimal. It almost appears as if the cabinet melted a bit. It is not cracked or punctured in any way. When the TV is on the picture is out of alignment on the corner with the damage. The picture on the left side is about 1 inch lower then the picture on the right. The picture on the right is also slightly lower then it should be I think. Subtitles or scrolling text are difficult to read. Is this something that can be adjusted back relatively easily (and cheaply)? i have a sony projection tv, all of a sudden my picture is not aligned. it looks like there is a red shadow. why would this occur and how can i fix it. i have presses the auto alignment button but the problem still persists....pls help, any info would be great
    Scholar:
  • 186 Answers
Look in the menu for a manual alignment. From there you should be manually able to adjust each corner and overall color alignment unless other damage has occurred. Try that first.
Posted on Apr 25, 2008
My 42" inch fried something
Ur tv still have picture,just have convergence problems wright?This tv is fixable,the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.Replaced all these parts on the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 16, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Have a Mitsubishi WS 55313 rear proj TV. Has been used maybe 30 hours in all. TV sat for a few years unused. Passed TV to my daughter. Once TV was reconnected at her house, she watched it in all its...
All old DLP tvs have a common design flaw,any time this could happen during the tv existing life,the tv problems is call a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead,the board have dead 2 STK convergence ICS and some or all of it resistors too.This parts on the tv convergence board,must me replaced,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 13, 2010 | Mitsubishi WS-48313 48" Rear Projection...
Picture shadow
Tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Mitsubishi WT-42413 42" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Vs 4571
you must replaces many electricaly capacitors located on video board
good luck!!
Aug 18, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Rear projection tv
Have you checked your convergence correction Amplifiers? These usually go bad. I believe they are the STK392-XXX (XXX stands for the last 3 digits) Mitsubishi uses the 500 series,They should be replaced with new ones and the bias resistors need to be changed also.
I would suggest taking it to a shop to have the replacement done, but if you want to do it yourself here is a site that can help:
http://www.hometheaterspot.com/fusionbb/showtopic.php?tid/79118/
There are many other sites that can help you install the ICs but this one is very accurate.
If you need any help in removing and replacing the ICs let me know and I will be able to walk you through the process(be prepared to take picture to help me see what you are looking at so I can help faster.
Thank you,
Shuttle83
Dec 07, 2007 | Mitsubishi WT-42311 42" Rear Projection...
I would open the back, behind the screen and see if the mirror mounts are damaged. if they are it could be almost impossible to alighn the set properly. good Luck
Aug 07, 2006 | Mitsubishi WT-42311 42" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
