Question about General Electric JBP65MMBS Range
Hot cooktop light stays on long after burners are off
    President:
  • 2,559 Answers
This is a normal feature and is used to warn of a hot surface.
Posted on Aug 03, 2010
  • MANNYAJA Aug 03, 2010
    i KNOW THIS IS A NORMAL FEATURE, BUT IT'S ON HOURS AFTER THE SURFACE IS WARM.
  • Randy Hough
    Randy Hough Aug 03, 2010
    I'm sorry i was only going by your limited info, If it remains on longer than it should the one of the temp sensors around the element has lost contact or gone bad..
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The light for the right back burner stays on,even though the burner is turned off and is cool
heatman101
Dec 25, 2010 | Microwave Ovens
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
General Electric JBP65MMBS Range Logo
393 people viewed this question
Top General Kitchen Ranges Experts
D. E. Hev
Vernon Taylor
Melissa Martin
Melissa Martin
Are you a General Kitchen Range Expert? Answer questions, earn points and help others
