Question about Epson MovieMate 25 Multimedia Projector
Large blue spot from projector - Epson MovieMate 25 Multimedia Projector
Yellow spot on VPl x1000 Sony projector screen
one of the three polarizers is burned up It can be repaired
Dec 27, 2012 | Office Equipment & Supplies
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
I just replaced all 8 bulbs in my projectors. we are a large church and they are used quite a bit each week. when i tested them yesterday, one of my projectors had a yellow dull spot in the center of my...
Hi
If spot is light ( like a clouds ) then probelm is with dust .if is dark then LCD panel is faulty.pl conatc your nearest service centre
ANS BY
M.R. Mumbai & Dubai
Aug 31, 2010 | Sanyo PLC XF45 Multimedia Projector
I have a panasonic pt l500u, just started getting large yellow spot in middle of screen- looks like a giant finger print. Bulb was replaced less than two months ago.
Hi:
The problem here is the one of the miniature LCD screens in the unit is faulty, in this case its the blue one. There are three of them inside the unit RED<GRN<BLUE. The blue seems to be failing in your unit, for instance if you mix red and green you get yellow. Have a local shop service the unit and clean and refocus the unit back to factory spec's..
Nov 04, 2009 | Panasonic PT-AX200U Projector
Blue spot on screen
there are light filters at each of the 3 lcd panels in the optical engine with a coating on them that determine the color. one of them (most likely the blue) is burnt from the heat and needs replacement. it could also be the fly-eye lens (whick evenly distribute the light) has burned as well. either way, it's very involved to replace, if you can get the parts. it's easier to have it sent in to get repaired.
Jul 31, 2009 | Canon LV-LP11 Projector Lamp for LV-7345,...
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Greenish/Yellow spot
Sounds like a scorch mark on the polerising filter, this can only be replaced by an engineer cost around £70 ($150).
Marc Engineer
Apr 05, 2009 | Mitsubishi LVP-X300 Multimedia Projector
Movie mate 30 brojecting blue spots on screen
it's the light polarizer on the blue lcd panel. it's fried due to excessive dust and heat. unfortunately you'll have to replace the optical engine.
Sep 04, 2008 | Office Equipment & Supplies
Blue spots on screen
Obviously this is not the first lamp you have replaced in you projector. These are great projectors however, the LCD panels expire quite quickly. You will find that the spots are related to the LCD panels needing to be replaced. This is not an inexpensive maintainence solution as the panels cost about $1500 each.
Nov 29, 2007 | Panasonic PTAE500 Multimedia Projector
Epson MovieMate 25 Multimedia Projector Logo
137 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
