My hitachi tv keeps turning itself on then a few minuts later off (onto standby), it refuses to stay on now. is there anything I can do? The model number is 42LD30U B I owned the tv set less than a year. Any help or advice will be gratefully appreciated. Lee
    President:
  • 1,099 Answers
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout,,,,
Posted on Aug 03, 2010
Samsung 6003 turns off and on by itself
Hello
You have posted to wrong place.
Regards
Ajay
Dec 06, 2011 | Samsung LN Cell Phones
When i switch my tv on it turn's itself to standby, i can switch it back on again but it just keep's switching itself to stanby after a couple of minutes.
You need a live input source to the port that the TV is set to, or turn on the tv and switch input to a live input source, anything else and the tv shifts to standby.
Oct 13, 2010 | Televison & Video
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
The TV switches it self off
Sorry to here about your TV problems but it is almost imposable to help someone with technical problems if they don't list a product, model or P/N number.
Either-way, I would try moving the unit in an area where it has more breathing space if poss-able.
Also, is the unit in a air conditioned area or in a Damp basement or Florida room ?
I would also, go on line and see if Panasonic has any call backs on this unit.
This may be a feature which can be reset without to much trouble.
Next time please list the size & model #.
Jun 16, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
We have a Hitachi C28W1TN, which is just under 10 years old that has recently started switching itself off. It goes onto standby by itself and when we switch it back on, it instantly does it again. At...
It's been a while since this post, but I may have had a similar problem with my Hitachi. With no reason it would switching on and off randomly. The problem was with a solder joint on main relay - it was cracked and would not keep the coil powered so i kept flickering on/off. This relay is located on the front of pcb, between high voltage area and the switch and on my tv it is blue. Check all four joints and apply some new solder onto them. Make sure the tv is not connected to mains ;-) Hope this helps
Oct 26, 2008 | Televison & Video
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
The flashibg red light
John, I do not know of a code, but it is a good idea in the design to have several goes at starting a circuit, before completely shutting it down. Oscillators are supposed to self start due to noise generated. Some electronic circuits require a reset pulse to be generated before the start up is allowed. The reset circuit may not be generated if the set is turned on again too soon, so it will stay in standby. This may normally be a few minutes to 30 minutes so it seems something in your set is faulty and could get worse. Try a test run with the back off and clean it out of dust with a long brush to keep it cooler. Make sure little fingers cannot get near it. Look to see if anything is obviously overheating.
Oct 21, 2006 | Thomson 24WK25U 24" TV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
