Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
I have a power mate black max 1800 psi 5.5 hp ohv pressure washer i need to know what kind of oil for the engine is used and the pump fluid thank you
2 Suggested Answers
SOURCE: My Durabuilt DB1303 pressure washer leaked oil. I
where do you find parts for your power washer? I have durbilt DB1303 and the adjustable spray nozzle started leaking, i look in my owners manual and the the wed site goes to some 3rd praty site that is not helpful. and the 800# they have in the manual you have to leave a message, so does any know where to get parts please help
Posted on May 24, 2010
WHAT OIL SHOULD I USE FOR THE HONDA BM80913A PRESSURE WASHER . I HAVE OIL FOR 2 CYCLE ENGINES BUT I AM NOT SURE IF I CAN USE IT. I do not have the service manual available
If you are asking about the oil for the gasoline engine then you can use a 30 weight engine oil like you would use in a car engine. Pressure washer pumps use a special non-detergent oil which is not the same as the engine uses.
Jul 16, 2011 | Honda Black Max 2600 PSI Pressure Washer
What oil does my troybuilt pressure wash use, its 4.5 hp unleaded gas 4500 psi? it just stalled while i was using it looked like oil was low, i have no manual and there was no info on unit so i added...
There is no way that a 4.5 hp engine can create 4500 psi. If you are putting the oil into the engine it would just take a 10w30 motor oil, if you are putting oil into the pump I would have to know what pump kind of pump you have, if the name isn't on the pump I would need to know the model number of the machine. The oil in the pump shouldn't have any affect with the motor not starting though.
Oct 24, 2010 | Briggs & Stratton Garden
What type of oil can i use
The engine and the pump can use the same oil. SAE 30 non detergent oil. No need to pay more for speciality oil. Check oil often and look for any unusual signs such as milky or foamy oil in pump which would indicate water leaking past seals. Good luck.
Sep 04, 2010 | Honda Black Max 3000 Psi Pressure Washer
What kind of oil do i use
Any good 20W-50 should work just fine in it. Also I like to use diesel oil in air cooled engines. Something like Rotella 15W-40 should be a great oil for your machine.
Jun 10, 2010 | Honda Black Max 2600 PSI Pressure Washer
I just bought a 2nd hand honda excell psi max vr 2522 2.2 gpm max 5.5 hp gvc160. i put gas and oil and it wouldn't start?
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Sep 25, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
JUST DON"T KNOW
I have one also all it required is 2stroke engine oil
May 11, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
142 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
