Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Picture works intermittenly then won't turn. blinker light blinks 6 times. what is the likely cause?
  • 4,472 Answers
This is actually a very common problem and is 2 IC's failing on the D board. They are about 6$ a piece but it is best to have some very good soldering skills before you attempt this.the IC's are designated IC8002 and IC6501, they are both marked with the part number MCZ3001D Here is a link to the part and you would need 2:
http://www.bluestar-online.com/MCZ3001D_p/mcz3001d.htm
Thank you and good luck,
Lee
Posted on Aug 03, 2010
Signal lights only work intermittenly
The blinker relay is getting worn out. It's right behind the hazard lights switch. Pull off the black trim around the radio, hazard, ets, and the relay is write there. Next time the blinkers stop working hit the hazard button or hit the trim just above the hazard lights button. Mines been doing it off and on and I just hit the trim above the hazard button and they start blinking again. Never have time or remember to get a new relay.
Sep 07, 2014 | 2001 Pontiac Grand Am SE
97 jeep wrangler 2.5
dont break the brakes..... TURNS & HAZ
many blinker, modules , internally flash with any load.
1: check all fuses first... (SOP)
2: then remove the blinker loads from the timer.
see it here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
see WIRING, (end)
8w-51/52
chapter 8w, page 51-4 shows the switch. (complex it is)
note how brake and turns are shared, resources. (blub elements)
now 8w-52-6
see the flasher module.
see C305 pin 2, any load on that pin will cause it to flash.(inside)
that would be any switch in the combo switch stuck on.
Apr 07, 2014 | 1997 Jeep Tj
Turn signal
Sounds like you may have the wrong bulb installed causing feedback to both circuits
Oct 30, 2017 | 1995 Volkswagen Jetta
My right rear turn signal stays solid, won't blink, in the vehicle the right blinker light blinks excessively fast, I have a 1999 surburban
Sounds like a bad ground to me, although i am no expert.
i would be checkinh all connections and take it from there, a little wd40 might just solve it short term.
Nov 26, 2011 | 1999 GMC Suburban
My blinkers work intermittenly and then not at all. what is causing that on my 2000 vw beetle?
Either the signal lever or the blinking relay are defective. Replace the relay , if this doesn't fix it then replace the lever.
Aug 27, 2010 | 2000 Volkswagen Beetle
Left blinker problems
That's an issue with wiring somewhere alont the line. There has to be a short somewhere. Hopefully for you the short is from the new taillight assembly being installed and it would be relatively easy to get to. Hope it helps!
Jul 03, 2009 | 1991 GMC Sonoma
Right read blinker/break light dont work, turn signal blinks rapidly
It's the bulb. There are two filliments in the bulb. One is for when you turn your lights on and the other is for breaking and blinker flashing. When the break filliment goes bad it causes the blinker to flash very rapidly. 100% the bulb. Change it and all will be good again. P.S. if it were a fuse none of the break lights or blinkers would work.
Apr 20, 2009 | 2005 Ford Explorer
Fast Blinker
Usually a fast turn signal means that there is a light out. You should probably check all of your lights, including back-up lights, and turn signals. If there is one out then replacing the burnt out bulb should fix the problem.
May 10, 2017 | 1997 Jeep Grand Cherokee
1995 GMC Sierra 4x4 - Having tail light problems
Most likely it is a groung issue where your rear wiring harness grounds to the frame. There may also be additional grounds for the wiring harness along the frame before the ground by the rear bumper. One other option is to make sure you have the correct bulbs in. I have seen something pretty similar to that caused by improper bulbs. Make sure your bulbs for the brake light/turn signal have dual filaments as that could be an indication you have the wrong ones; if you have the bulbs I think you do.
Mar 12, 2009 | 1995 GMC Sierra
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
201 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
