Question about Hoshizaki Commercial Freezer KM-900MRH3
Stopped working, checked power supply, which is fine. but wont turn on.
    Guru:
  • 1,524 Answers
The micro switch that is activated when switching from wash to refrigerate is most likely worn. Try jumping it out.
Posted on Aug 04, 2010
Frigidaire ED5GTFXKQ02 not working
First make sure its input power supply is as per required coming or not if its OK then check thermostat device it may can faulty kindly check it if its required then need to replace it .
Hope answer the question
Aug 17, 2016 | Frigidaire Refrigerator Replacement Frigid...
My chest freeze just stopped working. Have checked
Your start relay or overload relay must have gone out. What is the model number of your unit?
Jul 30, 2011 | Frigidaire Freezers
The freezer stopped working and it does not freeze
check power supply , thermostat or the compressor
Apr 13, 2011 | Electrolux Freezers
Icemaker stopped working suddenly. Water supply is working fine.Ice freezes but will not dump into bin.
Good day,
If the ice maker is the style with a wire to turn it off and on, and is in the down position, then the ice maker is bad, as long as the temperature in the freezer is 12 degrees or colder.
(The ice maker locks out at about 14 degrees or warmer.).
You can replace the module, and thermostat in the the ice maker, but could be as well the mold heater.
The price of repair is so close to a complete ice maker, that it doesn't pay to repair.
You might want to get the complete model number. Check with any decent size appliance parts house, they should have what you want, if going to Sears is an issue.
Feb 04, 2010 | Kenmore Freezers
I have a side-by-side (MDL: 106.53552202). My ice maker has stopped working... I do get water from the door. The ice container is empty, the switch is turned ON.
there could be a blockage of frozen water in the fill tube of the ice maker.
if there is no blockage then the nex thig to check is the main water valve that supplies the water to the ice maker.
you can check the power from the main pcb board to the ice maker and make sure you have current to the ice maker
if all else fails replace the ice maker
i hope this has helped in some way good luck
Jan 31, 2010 | Freezers
Water dispencer and ice dispencer stopped working
Make sure the water supply line is turned on (the valve probably is behind the fridge or under the sink ) also check if is kinked or damaged.
Aug 25, 2009 | Kenmore Freezers
ICE MAKER NOT MAKING ICE, WATER NOT FEEDING INTO ICE MAKER
you may have a frozen inlet tube coming in to the ice maker. This is caused from a bad water valve and you would need to replace the water valve.
Apr 02, 2009 | Frigidaire Freezers
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 | Freezers
Cold tech commercial reach-in freezer
sounds like an issue witrh the microprocessor to me as well, although you tried bypassing it it still didnt work its quite possible that the fan aand compressor are runnig on different voltagfe the 110v , new energy effient compressors are starting to run w/ 220, an inverter built into the circuit board could be steppin up power,
Apr 08, 2008 | Freezers
Hoshizaki Commercial Freezer KM-900MRH3 Logo
52 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
0duro
Level 1 Expert
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
