Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Wont move,has suction but wont move? - Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
  • 106 Answers
If cleaner is pulsing, you probably have a worn out foot pad and it should be replaced. If it not pulsing, you probably have a ripped or torn diaphragm and it needs to be replaced. Also, make sure there is enough suction.
Posted on Aug 04, 2010
Creepy not working good suction it sticks to the bottom of the pool and wont move
If it is an actual Kreepy Krawler that Pulsates and you have good suction then you should look k side and see if something is stuck inside the diaphragm or if the diaphragm is torn then it has to be replaced.
Jan 01, 2015 | Pool & Spa
Viper moving very slowly and wont turn
check water flow to unit if ok take apart check hoses and belts
Sep 11, 2012 | Hayward Viper Pool Cleaner
It wont pick up using the wand
There might be a few things you can try.
First, does the vacuum have a dial or control to turn the suction to the wand? If so, make sure you've set or turned this so that the wand suction is activated.
Second, most wands have a suction control vent. If this has been uncovered, the suction will not work efficiently. Look near the area where the wand connects to the vacuum and see if you can locate the suction control vent. There should be a plastic partial ring that can be moved to cover or uncover the hole.
I hope this helps. If so, please come back and rate my solution!
Jun 06, 2011 | Bissell Vacuums
Suction is ok but it wont move around the pool
Try checking the following things that often happen when these automatic pool cleaners are not moving: First, make sure that the main drain and and all suction lines not being used are closed. You might be getting some suction, but it might not be enough. Also, check for debris in your filter and pump baskets. Make sure that your flapper is working. If it has debris, it can prevent movement.
Jul 28, 2010 | Pentair Kreepy Krauly Inground Automatic...
Has good suction but wont move
Is there a tile stuck in the condom shaped diaphram when you look into the cleaner from underneath. Could be any kind of rubbish make sure you look deep inside as debris gets stuck right at the top.
This diaphram is removable check also that it does not have a hole in it.
Cheers Bazzard
May 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Sounds like a clogged or damaged diaphragm. Unscrew the nut just above the handle and push the white tube downward until you can see the white(ish) rubber diaphragm. It should not be damaged or distorted. there should be a small uniform gap inside and should not have any holes other than the two ends. Replace if necessary.
Apr 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Sticking solid to the bottom wont move.
If you have to much suction This can keep the cleaner stuck in one spot. Once the cleaner sticks to the floor the flapper won't move because of low water flo. If the cleaner only sticks when it hits the main drain then you still have suction through the drain and need to shut it down or plug it off. The suction from the drain and the cleaner suction will cancel each other out and cause the cleaner to stick to the drain. A main drain is a misnomer it is properly called a deep suction, as it's job is to collect heavy dirt. The cleaner is a roveing deep suction and replaces the main drain. So you no longer need it and can feel free to plug it if you have to. Good luck.
Dec 22, 2009 | Universal Kreepy Krauly In-Ground Pool...
Lots of suction, but G3 won't pulse or move around pool
theres a throat in it. Its damaged or ripped take a close look at it . you can gey at your local pool store
Oct 05, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Hayward pool cleaner wont move
Make sure the feet have springs in place, move freely, and rubber not too worn. If that all looks ok, then probably too much suction pressure. Use gauge that came with unit to verify proper suction.
May 30, 2009 | Hayward Navigator Pool Cleaner
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
250 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
