Question about Samsung Kitchen Ranges
I bought a Samsung Electric Range-smooth top (model # RESF333ODW) about five years ago from Best Buy.. A couple of days ago I was cooking something on it and the top cracked. I've tried calling the manufactures and BestBuy and both of the warranties have expried.. Please let me what to do? Approx. how much it would be replace the top and where can I find the replacement part. Thanks a lot.
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
watugot
  • 290 Answers
SOURCE: How do you open the smooth top, on a Maytag range?
There will be 2 or 3 screws under the front edge of the top. Take them out and top will hinge up similar to the older models.
Unplugg the range before touching any wires. There is voltage on the thermal limiter on the element even when the switch is off.
Once you have access to the element you can check for power and continuity just like on an older range.
Post back with any questions. I will see if I have a manual on pdf.
Thanks/Mike
Posted on Nov 04, 2007
SOURCE: Dynasty DGRSC 30 Gas Kitchen Range parts replacement
Have you tried contacting Jade Products who manufactures Dynasty ranges? 866-607-5694
Posted on Dec 28, 2007
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore electric
Here ya go...
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
Unplug the cook top and leave the elements in place.
Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
Remove the surface element assembly leaving all the elements wired together.
Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Lower the new cook top into place and secure with screws.
Good luck and I hope this helps.
Posted on Apr 08, 2008
  • 210 Answers
SOURCE: LG Kitchen Series Electric Range Smooth touch controls POSESSED!
The is a tough one if there is no tech there. I have not heard of this problem as yet. There could be a loose connection in one of the ribbon cables or it could just be a defective board.
You can try putting it in to test mode to see if it can self diagnose itself.
Press 'favourite' and 'settings' at the same time, 'diagnois' will appear, press them again and the prompts will appear. Note make sure the top surface is clear as well as the oven. If an error pops up at least you will know what is wrong with it. There is also a tech sheet on the back with the fault codes.
side note, do not put alluminium foil on the bottom of the oven cavity.
Sgt 48
Posted on Jun 01, 2008
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
What kind of glass cook top repair creme do I need for Firdgidaire Model FEF353BFW
Hi stormsdestin - Thank you for your post! The electric range, model number FEF353BFW is recommended to used warm soapy water to clean the electric cook top. If your cook top is broken or damaged, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. However, if you are requesting information on what kind of cook top repair creme may be use I would personally suggest contacting the manufacturer directly.
Apr 06, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a electric smooth cook top range. The front left burner is not heating up when turned on. The on indicator on the control panel is lighting up when turned on but like I said before, no heat in the...
-Most likely the connector of the burner is burn out.
-Check it out. If it is then just buy 1 from Lowes or Home Depot to replace. You should be good back to cooking business.
Good luck
Mai
Dec 14, 2017 | Amana ACF4215 Electric Kitchen Range
How do I get scratches off the smooth cook top on my range?
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. . We buy DeBruce at debrucepolish.com.
This IS the answer for cleaning an maintaining. Will not remove the heavy scratching in glass.
Jan 16, 2010 | Amana ACF4215 Electric Kitchen Range
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
Maytag cook top too hot!
Remove cooktop and check to see how much insulation is below the top, on top of the oven cavity, You may want to install some more insulation. The specs for this range probably allows this to happen. you should not put anything on the top after cooking in the oven, as glass breakage may occur.
Dec 04, 2008 | Maytag MER5775Q Electric Kitchen Range
Cracked glass top
Your crack was most likely cause by a flaw in the glass top. Most GE smooth-top ranges (espesially if manufactured prior to 1/1/06) have a five year warranty covering this type of failure. The labor is not covered after the first year. Check the back pages of your use and care book for warranty info on your model. I'd advise against continued use of the cook top with a crack, as spills can get to components and cause further damage.
Aug 21, 2008 | GE Spectra JBP78 Electric Kitchen Range
Smooth Top Electric Range
You didn't specify which type of smooth top - some, like the induction require special cookware. For the typical radiant type glass top nothing special is required.
Jan 03, 2008 | Kitchen Ranges
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Kitchen Ranges Logo
Top Samsung Kitchen Ranges Experts
Marvin
Marvin
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
