Question about Watches
I need to set the time and date manually - Watches
  • 103 Answers
Pull your stem out slightly to the middle setting for date and all the way for time.
Or if it doesnt have two settings in the stem you may have to turn until its correct.
Posted on Aug 04, 2010
U watch users guide how to set up to use
You can download PDF manuals for Uwatch smartwatches here https://smartwatchmanuals.com/uwatch-smartwatch-pdf-manuals/ Uwatch Smartwatch PDF manuals SmartWatch Manuals
Jan 31, 2017 | Watches
How to set time on polar rs300x
Access watch settings scrolling by UP/Down button.
<Settings> <Ok> <Watch> <Time and Date Settings>
In Time Settings:
Set the local time (Time 1) and a time difference to it (Time 2).
With Time zone, you can select which time zone is used.
In Time view, you can easily change the time zone from Time 1 to Time 2 by pressing and holding DOWN.
Set the date with Date setting.
You can also download the user manual from the link below
http://www.polar.com/e_manuals/RS300X/Polar_RS300X_user_manual_English.pdf
Oct 06, 2015 | Polar RS300X Watch
I need to change the date on my watch and don't have the instruction manual. Thanks!
mcdevito75 here, Sounds like you have the time set, but the date is a fifferent matter, Here"s what to do, the stem (winder) of your watch has 2 positions, slip a fingernail just under the stem, and gently lift the stem to it;'s first position, this position allows you to change the date without so many cycles of the entire watch, it"s a little tricky but you"ll get used to it. Once you get this first position set the date to 1 day before the date you want, now pull the stem out to set the time of day, go thru 1, 24 hour cycle to set the date you want and time of day. The date is now set and will change on time, approx. Mid nite. Hope this helps.
Aug 03, 2010 | Watches
I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Mar 28, 2010 | Timex Watches
I've got a breitling superocean chrono and want to set the time, how do i do this?
Keep in mind that I dont have the watch in my hand... :-)
If this is an authentic Breitling...
You should have 2 buttons on the right with the crown between them. The crown screws down so you need to unscrew it before you attempt to set! Once unscrewed with gentle pressure pull the crown out. There should be 2 clicks, pull to 2nd click or furthest distance from case. That should be the time setting mode. Turn clockwise until the date changes then set your time. To change the date push back to the 1st click and that should be the date set mode. One direction will be for day and the opposite will be date. I believe that if you pull the crown back to 2nd click and push your buttons that should change the subdials for chrono. You might need to push both buttons at the same time.
Ive set Breitlings before but they arent a common watch we see. Most people dont use the Chrono so if the directions dont work for setting those then I wouldnt worry too much about it! Not many people are going to notice those. :-) Also be so very careful if its a real Breitling as they are a very expensive to fix! :-)
***DONT FORGET TO SCREW THE CROWN BACK DOWN OR YOU WILL GET WATER INSIDE THE WATCH!***
Jan 08, 2010 | Breitling Watches
My date just will not set, it clicks two times but doesn't move
it's time for a overhaul and cleaning...the stem may be worn out. Rolexs need this service about every 10 years.
Jan 18, 2009 | Rolex Day-Date President 118238 Wristwatch
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Jan 09, 2008 | Citizen Eco-Drive BL5184-56L Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
