Question about ITT Jabsco Jabsco 135 Sl Remote Control Searchlight Replacement Bulb
Light turns on and moves up and down but will not go from side to side only clicks, I removed the light and the gears looked good. could it be the control itself?
  • Bob Balaam May 04, 2013
    I have a similar problem - up and down works; left and right does not - and there isn't even a clicking noise. Is it the wiring, motor assembly, or something else.
    Problem Solver:
  • 3 Answers
Chances are that it may be a ceased motor assy.
I had same problem & solved it by replacing motor assy.
Suggest unwire it & remove from unit and apply 12v to terminals (either way round)
If the gear wheel does not turn slowly then that is where your ploblem lies.
Replacement motor not excessively expensive.
Posted on Oct 23, 2010
2007 Yamaha Road Star Silverado neutral light stays on
Hi, Yexer #2 or #5 and the usual suspects are:
1. Neutral light bulb burnt out.
2. Faulty neutral switch.
3. A loose bulb in the socket.
4. Faulty wiring from the neutral switch to the light.
5. If the neutral light stays on while the bike is in gear the wire from the light to the neutral switch is grounded.
The ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
The above checklist is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Neutral switch issue
Forums The Roadstar Clinic
Yamaha XV1700PCRC Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 15, 2018 | 2007 Yamaha Road Star Silverado
My2002 R1 won't start no green neutral light when I turn the key the yellow check engine light lights up
Hi, Kevin the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
This check is most reliable if performed with a warmed-up engine.
neutral light wont come on when in neutral and wont start with kick stand.
No neutral light bike won start
Yamaha YZF R1P Service Manual
OEM parts for Yamaha
Yamaha YZF R1P Owner Manual
Sep 22, 2017 | 2002 Yamaha YZF-R1
Triumph trident 93 model side stand works as it should but warning stays on with stand up john
Hi, John either the switch is faulty or the circuit is grounded to the light that being said the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Side stand bypass
Sidestand Clutch Safety switch issues
Triumph TROPHE Service Manual Page 2
http://www.triumphestore.com/
http://mybikemanuals.com/triumph/uncategorized-triumph-owners-manuals
May 09, 2017 | 1993 Triumph Trident 900
I have a 2006 honda shadow aero. engine dies when put in gear. kickstand switch measuers good at plug...clutch switch measures good...clutch disengages properly...what else can it be?
Hi, Dan the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Dies when put it in gear 2003 Honda Spirit VT 750
Bike only starts in neutral and Dies when put in gear
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C 2005 Shadow Aero Owner Manual
Apr 29, 2017 | 2006 Honda Shadow Aero
1995 KLE500 Kawasaki: neutral blue light doesn't show and when clutch is released to engage in gear, engine cuts off
Hi, Ishmael the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Kawasaki KLE 500 dies when clutch is released
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/66113-gears-wont-engage.html
Kawasaki KLE500 Service Manual
OEM Parts for Kawasaki
http://www.kawasaki-techinfo.net/searchOM.php?view_lang=EN&spec=OC&
Apr 11, 2017 | kawasaki KLE 500 Motorcycles
Neutral safety switch problems 1992
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
1500 goldwing neutral light wont come on GL1500 Information Questions...
Neutral safety switch GL1500
Honda GL1500 Service Manual
Honda GOLDWING GL1500 Owner Manual
Apr 30, 2014 | 1992 Honda GL 1500 Interstate Gold Wing
Cd does not eject from kenwood kdc-138
First if your still under warranty return for new player if not carefully remove top and bottom covers check for any clear tape holding cd door shut or Look at LED sensors blocked by strofoam or cardboard that may have gotten inside the home position guide (the tray that holds the CD) the LED's are located at the front where the door first opens and at the rear where the CD goes deepest into the player,lightly clean with cotton ball and alcohal first remove hot wire ,Now turn cd player upside down and tilt side to side listen for loose screws or other debree check make sure belts are all tight by lightly tugging with index finger turn gears only one eighth of a turn never force anything, if they move that is a good sign, by moving the gears out of position when it is turned back on it will try to find home position, reconnect hot wire and try CD player again.Do not get grease on LED's make sure there is nothing on the CD like a sticker making the cd to thick will clog the device.if still no joy hand turn the gears until the cd is all the way out.Try different CD again never force good luck
Aug 26, 2012 | Kenwood Kdc-138 Car Cd Deck Auto Stereo In...
2001 YAMAHA ROADSTAR will only start if kickstand is UP not DOWN and clutch handle pulled in for some reason it thinks bike is in gear but it is not. The neutral light is on bike drives good and shifts...
Hi, Layton_dille the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Re only start neutral dilemma Road Star Forum Yamaha Road Star
neutral light wont come on when in neutral and wont start with kick stand...
May 07, 2012 | Yamaha Road Star Motorcycles
Oster A5 clippers are slow and vibrating noisily even without a blade attache. Any ideas what could be wrong with them please as I have a dog only half clipped at the moment. Thanks
If the nylon lever (the tab that moves the blade back and forth) is not moving with the blade off, or only moving sometimes, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever (the nylon part that moves the blade) Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon carries both single speed and 2 speed gears under Oster A5 clipper parts. All these parts should have a light coat, where they move, of lithium grease, and the two pads (one on each side of the lever) should be oiled. You might also check the condition of your brushes (under the caps on each side of the clipper. Take cap off, remove cover from brush, remove spring and brush to see how worn they are).
Good luck.
Aug 10, 2009 | Oster Golden A5 2-Speed Universal Motor...
Fixable A5 Clippers?
If the power lever (the tab that moves the blade back and forth) is not moving with the blade off, or only moving sometimes, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever (the nylon part that moves the blade) Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon2.gif carries both single speed and 2 speed gears under Oster A5 clipper parts. All these parts should have a light coat, where they move, of lithium grease, and the two pads (one on each side of the lever) should be oiled. You might also check the condition of your brushes (under the caps on each side of the clipper. Take cap off, remove cover from brush, remove spring and brush to see how worn they are).
Good luck.
Jun 03, 2009 | Oster Golden A5 1-Speed Universal Motor...
ITT Jabsco Jabsco 135 Sl Remote Control Searchlight Replacement Bulb Logo
824 people viewed this question
Top ITT Jabsco Boating Experts
Mike
Steve
Steve
Bill Boyd
Are you an ITT Jabsco Boating Expert? Answer questions, earn points and help others
