Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fault code 130 - fisher and paykel intuitive iw812
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now Error Code 130 means the fault on your machine is called Single Rotor Position Sensor Error.This means the Rotor Sensor which is located on your motor is faulty or the wiring to the rotor sensor is faulty or the Control Module that reads the information from the rotor sensor is faulty.Now to test the wiring you need an electrical tester to check if the wires going to the rotor sensor are broken but unfortunately to test the Rotor Sensor you need a device called RPS tester.If you eliminate the wires as the fault, which is not too difficult, and change the rotor sensor without testing it the fault could be the Control Module.I am sorry I cant help you test the rotor sensor without an you having an RPS tester.Please reply and let me know how you would like to proceed and I can help you as much as I can .Looking forward to your reply.
Posted on Aug 04, 2010
The problem 10000% is the drain pump. Change that-only one clip and a turn, just underneath the front of the machine and you problem is solved. Cost about $95 if you don't have a trade account. Also, you can get a generic model which is identical. They are all made in France anyway. Cheers.
Posted on Feb 29, 2012
What is error code 130 fisher & Paykel intuitive eco IW812 ?
the R.P.S or rotory postition sensor is faulty or the connections are corroded
Jun 29, 2014 | Fisher and Paykel IWL12 Top Load Washer
My washing machine IW812 has fault code 37.Could explain what that is please?
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
Nov 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
F&P Intuitive washer IW812 very noisy water
Traced the problem back to the tap. Seems the washer in the tap was faulty and producing a screaming graunching noise. Replaced the washer and all OK
GK
Nov 12, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Service fault 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Apr 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,881 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
