Question about Troy Bilt Tb70ss Gas Trimmer
My troybilt string trimmer has been sitting for awhile and will start but not keep running unless I continually push on the primer
  • tilchristcom Aug 03, 2010
    this is a 6 hp string trimmer that rolls on two wheels like a push mower
  • 2,973 Answers
Friend, As the device has been idle for sometime, it needs to be clleaned/serviced. The fact that it starts but has to be pushed to keep running means that its fuel line is dirty or clogged. Please clean the fuel system or get it done and it will be just like a new one.
Posted on Aug 03, 2010
  • Rinoo Kumari Aug 04, 2010
    OK. The answer is still the same. Also add cleaning of spark plugs to the list. Basically it is the fuel not reaching the carb. And if it doeas then the spark plugs do not have the blue spark due to carbon deposits or improper gap. When it gives a blue spark and has enough fuel, the machine will work.
    To be on the safe side also clean the air filter as the machine has been lying idle.
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Motor starts and runs fine but trimmer heads only spins slowly
replace the centrifugal clutch at the motor end of the unit shaft
Jul 18, 2015 | Troy-Bilt Troybilt Mtd String Trimmer...
I REPLACED THE PRIMER BULB AND NOW THE TRIMMER WILL NOT IDLE UNLESS IT IS AT FULL THROTTLE
Try swapping the hoses at the primer bulb. You may have put the return hose on the purge side of the primer bulb.
Sep 04, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Troybilt trimmer primer bulb collapses. it will start occasionally but will only run a few minutes.i have replaced the primer bulb and gas lines and still have the same problems.
it should have a small vent in the fule tank cap if its blocked the primer bulb will be sucked in as the fule pump can **** any fule from the tank
check the tank cap first,,,,,
Aug 08, 2010 | Troy Bilt Tb70ss Gas Trimmer
MY HOMELITE STRING TRIMMER UT21505 PRIMER BULB LEAKS. MY PARTS LIST DOE'S NOT SHOW THIS PART. CAN I PUCHASE IT OR DO I HAVE TO THROW IT AWAY
You can easily get a new primer bulb for it...most small engine repair shops will have what you need, and if you want, you can most likely snag one on Ebay....DON'T THROW IT AWAY, ok?
Jul 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
Won't start
drain fuel tank. keep depressing the primer bulb until it is clear. drain tank again. remove carb cover and disconnect lines one at a time. keep depressing primer bulb to get rid of excess gas. remove spark plug an turn engine in a position that the spark plug inlet is facing the floor, pull starter rope a few times to get rid of gas in the engine chamber.
Oct 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Describe your troybilt tb70ss pull string Problem.
Do you have mfg instructions? Can be very tricky without following instructions
Sep 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
47 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
