Question about Maytag MDG7600AW Gas Dryer
My dryer tumbles and it gets hot but there does not appear to be any air circulating. My clothes are not drying and when I open the door it is very steamy. Any suggestions? This happens consistently which makes my dryer run and run and run.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Sounds like an obstruction (lint) in your vent. Check for proper airflow out of the outside vent and compare it to the air coming out the rear of dryer.
Posted on Aug 04, 2010
  • Sal De Jul 09, 2011
    i didn't see that this is an old message,it popped up when i answered someone else and i answered this and then it told me this is from last year,sorry
  • Maytag Master
  • 2,699 Answers
You could have a bad blower wheel.remove the vent line from the back of the dryer and start it,if you don't feel air blowing out of the back a good flow of air check the blower wheel. open the door,remove the two phillips screws that hold the door on and then remove the other two screws on the other side,you can leave the door on,now grab the top of the frame on the left and right side and pull the panel forwards,then tilt it forwards and slide it off of the bottom tabs, close the door and start the dryer,usually if the blower wheel is damaged you'll hear it banging around as it starts to spin,to get at it unplug the dryer,then ther are four 5/16 inch screws that hold the bulkhead on,the bottom two come out and if you look at where the screws go in you'll notice a cutout,the shorter screws go into the cutouts and the longer screws don't,when you remove the bulkhead you'll see the blower wheel,grab it and move it around,it should be tight,if it moves you'll know it's bad,remove the 1/4 inch screws and then the 5/16 inch screw to remove the cover,with a pair of plyers remove the clip and pull off the blower wheel,part 33002797 and it's around 25 dollars.this is if the wheel is bad,if air blows out the back then you have a blocked vent line,if it's a long run you can use a leaf blower to blow out the line,you should do this once a year to keep the line clear anyway and clean out the dryer,clean out the duct that the lint filter slides into and vac out the cabinet where the motor is.let me know how you made out.
Posted on Jul 09, 2011
  • Sal De Jul 21, 2011
    also open the door,push in on the door switch,the little paddle that the door hits when you close it and make sure the drum is spinning,the belt could be broke
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Hi super capacity dryer - tumbling ok, apparent hot air when door is opened, but clothes still damp after about 90 minutes of drying time..also no visible lint in lint trap..? any suggestions? thank you
ventilation problem,disconect hose from back of dryer make sure lint trap is clean turn dryer on clothes should dry,if they do your is bad or vent to house is stoped up
Jan 23, 2011 | Whirlpool Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
My dryer gets hot but my clothes come out hot and wet. Like its not getting air circulating. I cleaned the vent, but it still doesn't dry clothes
Did you clean all the venting inside and out? Also, there is a flap inside right before the vent. It opens to allow air and closes to heat up and close air off. Sometimes this flap can get stuck
Aug 06, 2010 | GE Dryers
Once we put a load of wet clothes in the dryer after about 3 minutes the dryer shuts off. The top of the dryer becomes extremely hot. We open the dryer door and let it cool down and then the dryer starts...
Wet clothing doesn't allow proper ventilation while tumbling clothes. This in turn causes electrical shorts: steam in chamber and reduces airflow. Reduced airflow will will cause the drier to shut off on an over temperature condition. Moral of story, spin clothes as dry as you can and when tumbling, make sure you have good ventilation to get best results.
Sep 26, 2009 | Dryers
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
137 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
