Question about Kenmore Dryers
Dryer runs but no heat. changed thermal fuse and still no heat. what else could it be and how do i get to it. i have a kenmore model #11070802990
  • Kenmore Master
  • 1,527 Answers
Hello 1 of the heat sensor could be faulty these sit behind the element usually right the back of the dryer there may be 2 of them if so change them both good luck
regards
shaun
Posted on Aug 04, 2010
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
My name is Peter. I am a retired field service appliance technician.
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
The unit runs but no heat.
Your limit switch has tripped. You will find this small switch near the burner that is the size of a dime. Press the small button between the wires firmly to reset it.
Apr 16, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
May 05, 2008 | Kenmore 63942 Dryer
Dryers Logo
90 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
