Just appeared when i moved it from one room to another,vertical line close to right side
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the manufacturers name and model no# of your TV so that I can assist you further.
Thanks
Rylee
Posted on Aug 03, 2010
  • 2 more comments
  • roddavidson Aug 03, 2010
    It is a 50" Toshiba 50hp66 plasma
  • Rylee Smith
    Rylee Smith Aug 03, 2010
    From what you have described it seems to be the issue with Y-main however, Y-buffer and the logic board should also be checked. These boards are located on the right side of the unit and to check them you’ll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • roddavidson Aug 04, 2010
    fine yesterday,only move set 25 feet and rehung,anyother suggestions before I call a repair center?
  • Rylee Smith
    Rylee Smith Aug 04, 2010
    Leave the unit unplugged for 4-8 hrs..it might be due to a bad connection internally however, to check that you'll have to open the unit.
Hi my Samsung plasma TV PN50C550G1f has a thin light colored vertical line on the left and right sides. The lines appear when using cable or Roku. With menu on, the lines appear over the menu.
Sounds like signal radiation from these devices which comes down to proximity or poor cables (screening) to me this is like the old days with video's under TV's causing lines and I would put a metal tray between them (or a silver one in some places).
If its proximity then move a metal tray or similar around during this event to see if you can find a spot when it clears or reposition an item. If its leads then close your hand around a cable this should make those lines vary if so obtain better types or move them around to better positions (called dressing cables).
Hope this helps..........
Aug 28, 2017 | Samsung Televison & Video
Samsung plasma tv has vertical lines
The most cost effective thing to do is just replace the TV. The cost to repair will be close to the cost of a new LED flat screen, they are very cheap now.
Aug 21, 2016 | Samsung PN51F8500 51" Full HD 3D Smart...
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
TOSHIBA 50" MOD.#50HP66 appears vertical
A part of the buffer memory from the image processor is faulty and all the data stored in there is corrupted, hence the lines you see.
What you must replace is the board on which the processor is situated, the logic one. Here it is
http://www.partstore.com/Part/Toshiba/Toshiba/50HP66/Toshiba/Toshiba/75003034/New.aspx
Feb 26, 2011 | Televison & Video
A group of 16 vertical black lines have appeared
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Mar 26, 2010 | LG MZ-42PZ14 42 in. Plasma Television
A white line has appeared on my desktop only
Two inch vertical line appeared.It sometimes is on the left and sometimes moves to the middle. It is only on the desktop.
Feb 20, 2009 | Microsoft Windows XP Professional for PC
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blue colour is ghosting off to the side
blue convergence IC needs replacing. That should have 3 ICs one for each color if so you only need to replace the blue. but if it has only 2 ICs then you will need to change both. If you need further info let me know.
Mar 19, 2008 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
