Question about Uniden BC246T Handheld Scanner
The Scanners Plugin does not charge the scanner
    President:
  • 2,761 Answers
There are at least three possible causes.
1. Dead/worn out batteries. If your batteries are more than a year old there's a good chance that it's time to replace them. Before you do that, though, check the batteries with a volt meter or try using them in something else that uses two AA batteries. If the batteries check out OK, then your problem is likely #2 or #3 below.
2. Bad charger. Check the output with a voltmeter or try charging another set of AA batteries (in the scanner) with it.
3. Corrosion buildup on the battery terminals and/or contacts in the scanner. If no buildup (usually a white, crusty substance) is visible, wipe both ends of the batteries, and the contacts inside the scanner with a clean, dry cloth, and then try charging them in the scanner. If there's a visible buildup, you can clean the batteries and scanner contacts with a fine wire brush, steel wool, or fine sandpaper. Be sure to remove any residue from the battery compartment before you reinsert the batteries.
I hope this helps.
Bill B.
Posted on Aug 03, 2010
My ls4278 is not lighting up when on the cradle, will not scan or charge...i have 3 scanners and cradles and somehow all the scanners stopped working completely..all the cradles have the light on but when...
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
May 18, 2011 | Symbol LS 4278 Barcode Scanner
Where is the power button on a canoscan lide 70 scanner?
There is no power button on mine. It gets its power from the high speed usb so it is always ready. Every time I boot up my mac I hear the scanner go thru a warm up scan. I have downloaded the twain plugin for photoshop and access it that way. The lamp will go on when you preview scan something.
Feb 19, 2011 | Canon CanoScan LiDE 70 Flatbed Scanner
When i plugin my usb it shows the problem as code 43
Code 43 is an indication of an outdated program software on the scanner device. contact the device techical experts to provide the most innovated compartble update to the condition.
Feb 05, 2011 | Computers & Internet
The Ubuntu Linux system does not recognise the scanner
This scanner is supported by the SANE project (http://www.sane-project.org) and the info on your scanner is here http://www.sane-project.org/cgi-bin/driver.pl?manu=umax&model=astra+3400&bus=any&v=&p= . The scanner uses the sane-plustek driver. You need to install sane, xsane and sane-frontends and sane-backends. Once you have installed them you should be able to plugin and turn on the scanner and run xsane.
sudo apt-get install libsane-extras xsane sane-backends sane-frontends
Once you have installed all the needed packages start xsane.
Aug 13, 2010 | Umax Astra 3400 Flatbed Scanner
Where is the connector for the obd II scanner cable located on the 1991 Ford Taurus ?
It doesn't have obd 2, It has a eec 4 connector under the hood. They make scanners to read codes on these but if you scanner only has one plugin, it isn't going to work.
Apr 02, 2010 | 1991 Ford Taurus
My 1212u doesn´t show as being connected...installed scanwise 2.0 before and after plugin with same results...
I'm not certain you need to, but I would download and install SP3. I can remember that the sata drivers are included in one of these two service packs and I thinks it's SP3. Also check that your connecting cable is ok too.
Mar 31, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Trying to install CanoScan FB 360u on Mac OS X
1)Here is the Link to get the toolbox CLICK HERE 2)As for the plugin (Applications>CanoScan Toolbox 4.1>Plug-Ins) put one here after you have the toolbox installed 3)You must have photoshop of any version to do the next step 4)If you do Put it here (Where ever your photoshop folder is> Plugin)
And go mac's
Sep 30, 2009 | Canon CanoScan FB630U Flatbed Scanner
My polce scanner wont turn on.....do you think i shorted it out? HELP!!!
Was this binging used in a 12V dc matter? Its own battery? or plugin power supply?
Jul 23, 2009 | Uniden Radio Communications
Uniden BC248CLT BASE SCANNER
If it seems to be locking on a channel like someone is talking but no sound, it's possible that the speaker quit working. Simply plug in an external speaker into the plugin on the back. I have a BC 860 that the speaker recently quit. That's what I did and it sounds better. Good luck Mechanic
Jan 14, 2008 | Uniden BC248CLT Base Scanner
Not scanning colors correctly
it could be you have upgraded your software and need an upgraded plugin or driver here is a sorce i use for drivers http://www.driver32.com/brand2.html
Jul 02, 2007 | Apple UMAX Astra 3400 Flatbed Scanner
Uniden BC246T Handheld Scanner Logo
48 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
