It's a 1 TB ext. drive. It was working good 'til about 2 days ago when it wouldn't power up. What can I do it get it back up and running again?
    President:
  • 2,571 Answers
If it is the power adaptor, check it for faults.
If it is ok, check the usb cable.
It may also be the USB interface on the enclosure.
As a last resort you could remove the drive from the enclosure and buy a new one to put the drve in.
If the power adaptor needs replacing, it may be cheaper to get a new enclosure.
Check this 1 out, it is a cradle you can push your drives into without having the bother of fitting it inside, plus you can use any sata drive in it, if you have IDE drives, you can get an ide version also
It is £14
http://www.amazon.co.uk/NEWlink-USB-Docking-Station-SATA/dp/B001FB6WPK/ref=sr_1_15?ie=UTF8&s=electronics&qid=1280876424&sr=1-15
Posted on Aug 03, 2010
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
Jul 19, 2013 | 2004 GMC Envoy
Did not have instructions on operation to copy files from old computer can any one help?
well this requires three steps usually
a back up old files on ext drive
format new drive to receive files
restore old files to new computer hard drive or ext drive
i also recommend you do a disk optimizer on old files first to clean up any fragmentation click here for a good one
Jun 01, 2012 | Western Digital My Passport Essential SE...
1996 chevy 3500 7.4 vortec. the ecm fuse blows at the turn of a key
One of the power wire going from your ecm to a sensor or solenoid is shorting to ground. Get a wiring diagram and an ohm meter. disconnect the battery and start checking each wire measuring from the wire to ground. as you wiggle you will see the meter show 0 ohms when it is shorted. These are the hardest and most time consuming kind of electrical problems .good luck
Nov 21, 2011 | Cars & Trucks
I have had this hard drive for about a year now and it has been nothing but problematic. I reformatted like 4 months ago to ntcc as was advised it would make it more stable... It was great until a few days...
The bad news is that I think you have a bad drive. There's not much you can really do. A few little
things that you might try as a last ditch effort are make sure your USB connection is good use a good quality cable and hook up the drive to the back USB instead of the front this may help.
If the drive comes back alive try to backup your stuff right away. I wouldn't do this in very large
blocks and back up the most important stuff first. doing mass transfers of data can stress this drive even more.
If its a software problem, say some kind of malware is causing the problem get a copy of Linux Mint
and see if it will mount the drive. If its a malware problem Linux shouldn't be affected by it. Linux Mint is a Live Version that can be run from a CD-ROM and has all the tools to mount NTFS filesystems. and transfer data between them.
If a drive goes bad it usually gives signs it will click and whir continually with a funny rythym. If this
isn't happening then the drive may be good and the USB controller may be bad. If this is the case
the encased drive can be reomoved and unplugged from the USB controller and plugged into and
external hard drive cable or adapter.
If worse comes to worse one of your local computer repair shops may do data recovery BUT it can
be very expensive. If its your family picture album, your bands demo the've been working on for a year then going this route may be an option but backing up roms, mp3's and movies and such
will probably cost you more than its worth.
Apr 30, 2011 | Verbatim (96759) 1 TB USB Hard Drive
We have been using a 2 TB Samsung G3 Station External Hard Drive to connect to the TV through a laptop. One day it was working next day no power seems to be going through it. The light doesn't come on...
Assuming you don't hear any activity it might be the power supply that has died. Check if it's under any warrant.. if not you can always rescue the hard drive by taking it out of the enclosure and plugging it into your PC. Odds are it's a SATA drive. Either way.. taking it out of the enclosure will rule out of it's the hard drive or the components. Good luck.
Mar 19, 2011 | Samsung G3 Station Desktop External Drive...
Drive connected to HP Desktop running Vista Pro after one week and several re-starts PC would not boot on start-up showed scary blue screen with with drive connected without black screen then blue....
> after one week
Western Digital warranties the disk-drive to work for at least one year.
If it does not, then exercise the warranty to get a replacement, at minimal cost to you.
Try connecting it to a different PC, to see if your PC's "blue-screens" happen without it being attached.
Nov 18, 2010 | Western Digital My Book Elite...
UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Iomega 320 external hard drive computer wont recognise
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
Computers & Internet Logo
167 people viewed this question
Alun Cox
David Payne
David Payne
