Question about LG enV VX9900 Cellular Phone
Ok key and bottom row keys on front pad dont work
    Scholar:
  • 96 Answers
the problem is as a result of accumulation of dusts underneath these buttons,
However,the solution is to take apart the buttons and apply spirit with the help of a cotton wool.to clean out the button pads,please avoid the use of excess spirit on the cotton wool which may have adverse effect on the panel below the button.
Take care
Posted on Aug 04, 2010
How do I do a hard reset for my motorola blurr? I'm having problems with the touch screen sensitivity. It selects things that I don't touch, and doesn't select what I do touch, please help!!
  • If the device is responsive, back up all necessary data.
  • Power off the phone
  • While the phone is off, press and hold the Camera key, then turn the phone back on using the Lock/Power key
    • Note: Continue to hold down the Camera key while the phone boots up
  • When prompted, release the Camera key
  • On the USB FastBoot/BOOTLOADR MENU screen, press and release the Volume down key to enter the Recovery Mode
    • If done correctly, you will see VOLUME DOWN KEY PRESSED appear on the screen
    • IMPORTANT: You only have 10 seconds to complete this step before the device powers back on. If that occurs, you will need to start back at Step 1
  • When the "Triangle!" screen appears, tap the bottom right corner of the display to access the Motorola system recovery screen .
    • Note: If this doesnt work, Touch the bottom right corner and make a small circle gesture to access the recovery screen.
  • Highlight the row labeled wipe data/factory reset [Alt+W]
    • Note: You can use the touch display, volume up/down keys, or the Tinytouch pad to highlight the row
  • Tap Ok to begin the wipe/factory reset
  • When the wipe is complete and the device returns to the Motorola system recover page, highlight the row labeled reboot system now [Menu+Back]
  • Tap Ok to begin the reboot
  • When the device powers back up, you will see the MOTOBLUR setup screen and have the option to create or sign into an existing BLUR account
  • May 28, 2012 | Motorola Cell Phones
    Touchpad compaq 510 not work How check basic with me?
    You more then likely accidently switched it off click the Function Key ( It says Fn on it) this key is in the bottom left corner of your keyboard. Click that key while at the same time up in your top row of keys there should be an image that looks like your touchpad on one of those keys click that key at the same time that you press the Fn key and that should reactivate the touchpad. Let me know if that works out for you.
    Jun 19, 2011 | Compaq (153515-001) Touch Pad
    Where is the number lock on this keyboard?
    As with most laptops there is no number lock key. you dont have the number pad like most desktop keyboards. you have a (fn) key this works for all the keys that have a square around them it may be blue/white/purple, and is located on the bottom left should be the second key on the bottom left row right next to the ctrl key. but once again there is no number lock key.
    Feb 21, 2011 | Dell Inspiron 1545 Notebook
    The scroll pad doesn't work
    Hi, Inorder to get the scroll pad to work you need to press and hold down the Fn key located on the bottom row of the keyboard and with the Fn key held down push and let go off the F7 key and should be able to get the scroll pad to work. Thank you for your patience and best wishes for your effort.
    Jan 04, 2011 | Acer Aspire AS5520-5537 Notebook
    Bottom row of my keypad doesn't work
    You have to get it changed
    2G iPhone - FULL LCD with Touch Pad !. 3G iPhone - Only Touch Pad !
    Best Regards
    Jun 24, 2009 | Apple iPhone Smartphone
    The bottom row of my keys and numbers pad won't work
    If it is brand new, then you have warranty, I suggest you return it to the supplier to get it fixed, because if you do something to it you might void your warranty.
    May 17, 2009 | Dell Latitude D600 Notebook
    Every once in a while my key pad first letter row Q thru P and second letter row keys a thru L will not operate. When the letter q is pushed qa will come up on the screen and when you push the a key qa...
    Keyboard errors are Locale setting errors.
    check your regional languages in control panel,
    are set to english at the top, and save it.
    Should be good if hardware ok
    Regards
    Richard.
    Apr 14, 2009 | Computers & Internet
    Key pad
    open the front key face by placing a card on the side of the phone. careful not to poke it harder as there are some chips inside the front slide. once it is open, clean it or try to adjust the keypad face then place it back. If problem still exist, bring it to the mobile center for repair.
    Apr 09, 2008 | Nokia N81 Smartphone
    I need help wiring a pioneer to a 1992 cavalier cuz the wires dont mach up
    the cavalier wiring-top row is orange 12 volts regardless of the key switch position,yellow 12 volts when the key is on/or accessory, pink is for power antenna or factory amp turn on, grey is for lights dimmer control, black ground,green right front speaker +,light green right front speaker -,grey left front speaker +,tan left front speaker-, bottom row is brown left rear speaker +,yellow left rear speaker-,blue right rear speaker+,light blue right rear speaker- be carefull because you have 2 yellow wires and 2 grey wires if you follow the rows like I explaned you will be fine-If you need the wiring for the pioneer radio E-Mail me at merle840@aol.com
    Apr 04, 2008 | Pioneer DEH-1900MP CD Player
    LG enV VX9900 Cellular Phone Logo
    Top LG Cell Phones Experts
    skiffy99
    skiffy99
    Level 1 Expert
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
