Question about Moen & One Handle Tub & Shower Faucet
Do you have written instructions for taking out an old faucet and replacing it with the INS898D-3/09 faucet? The directions that came with are just pictures and I need more explanation.
  • John M Aug 04, 2010
    Good for you taking on this project. The first thing I will start with, is if you are not comfortable soldering copper then I would stop and call in a plumber to install the shower. If you have soldered copper in the past and are comfortable doing so then please proceed. Give yourself 2 to 3 full days to complete the project.
    You will need:
    Plumbing permit, available from your local munucipality. It will need to be inspected after the work is completed.
    Solder, solder flux and propane torch
    Heavy suede work gloves
    Water Spray bottle
    Pipe wrench
    Safety Glasses
    Hacksaw
    Deburring tool for copper pipe
    Emery cloth
    Tape measure
    Screw driver or screw gun
    Mounting Screws
    Old blankets
    5 gallon pail
    1/2" Copper pipe and fittings
    To begin we will have to uninstall the old shower. I find it helps to take photographs of the existing system so that you can see how the new one should go back together in case you get stuck halfway through the project and cannot see how to finish it off correctly. If you can access the shower from the other side of the wall, great. If not you will need to remove the shower surround or tile on the end wall where the plumbing is. Be sure to protect the tub with an old comforter or something to keep the tub from getting scratched up during construction.
    Before removing the old shower be sure to locate the shut off valves and close them. Turn both hot and cold on in the shower to remove any water pressure in the lines. Disassemble all the trim pieces of the old shower including the tub spout, handles, diverter and shower head. Take measurements of the existing piping to assist you when it comes time to cut and assemble the new copper. Do not reuse any of the old fittings. They will be very difficult to solder and new ones are very cheap.
    You should have 2 copper risers coming out of the floor, one cold, one hot. Cut them approx 12" above the floor. Repeat the same process for the tub spout and the shower riser. With all 4 pipes cut you can now remove the brass manifold from the 2X4 blocking. Disassemble the shower flange pipe from the copper shower riser. You should now have just the cut copper risers coming out of the floor. Use the deburring tool to clean the sharp edges where you cut the risers. This will aid in soldering the new pipe in and avoid you cutting yourself on the sharp copper while you work. To be continued.
    Scholar:
  • 67 Answers
Good for you taking on this project. The first thing I will start with, is if you are not comfortable soldering copper then I would stop and call in a plumber to install the shower. If you have soldered copper in the past and are comfortable doing so then please proceed. Give yourself 2 to 3 full days to complete the project. You will need: Plumbing permit, available from your local munucipality. It will need to be inspected after the work is completed. Solder, solder flux and propane torch Heavy suede work gloves Water Spray bottle Pipe wrench Safety Glasses Hacksaw Deburring tool for copper pipe Emery cloth Tape measure Screw driver or screw gun Mounting Screws Old blankets 5 gallon pail 1/2" Copper pipe and fittings To begin we will have to uninstall the old shower. I find it helps to take photographs of the existing system so that you can see how the new one should go back together in case you get stuck halfway through the project and cannot see how to finish it off correctly. If you can access the shower from the other side of the wall, great. If not you will need to remove the shower surround or tile on the end wall where the plumbing is. Be sure to protect the tub with an old comforter or something to keep the tub from getting scratched up during construction. Before removing the old shower be sure to locate the shut off valves and close them. Turn both hot and cold on in the shower to remove any water pressure in the lines. Disassemble all the trim pieces of the old shower including the tub spout, handles, diverter and shower head. Take measurements of the existing piping to assist you when it comes time to cut and assemble the new copper. Do not reuse any of the old fittings. They will be very difficult to solder and new ones are very cheap. You should have 2 copper risers coming out of the floor, one cold, one hot. Cut them approx 12" above the floor. Repeat the same process for the tub spout and the shower riser. With all 4 pipes cut you can now remove the brass manifold from the 2X4 blocking. Disassemble the shower flange pipe from the copper shower riser. You should now have just the cut copper risers coming out of the floor. Use the deburring tool to clean the sharp edges where you cut the risers. This will aid in soldering the new pipe in and avoid you cutting yourself on the sharp copper while you work. To be continued.
Now that everything is apart it is time to cut all the copper to proper size and mount the brass manifold on the blocking within the wall. Take a close look at the drawings on the instructions. The plastic piece that covers the brass manifold will need to be flush with the drywall so that when you install the escutcheon plate it is also flush with the drywall. Be sure to test fit all the plumbing before soldering to ensure. begin by soldering the fittings that will screw into the manifold. Once this is done begin reconnecting the plumbing system. Again I can't stress enough that if you are not comfortable or have experience soldering copper to bring in a licensed pro. Nothing worse than completing the job and finding its either not up to code or worse leaks and you have to back over the job. Good luck with your project and let me know if I can be of any further help. Sorry it took so long to finish this. I was out sick for about a week right after I completed the first part. Good luck.
Posted on Aug 10, 2010
Having great difficulty removing old Moen 1225 to install new one. Can not figure out why? Followed both written and video instructions. Any thoughts? Thank you.
Hi! You can buy or rent a cartridge puller for Moen's 1225 cartridge. Try Home Depot or your local hardware store or online at pro.moen.com part #104421
Mar 07, 2015 | Moen Plumbing
We are not sure of the model number of our faucet but the head is leaking. We tried replacing the washer but it didn't help. It is an oval desgn about 8-9 years old. Can we get a replacement for that? ...
I will try to help you.
The faucets with one-handle control have a valve cartridge inside the stem which needs to be replaced when a leak develops. Each manufacturer makes its own type of valve cartridge, so you must get exactly the valve that your faucet needs. The best way to do this is to remove the valve and take it to the hardware store when you don't know your model number. Each manufacturer also makes more than one valve so you must either know the model or take the valve in.
I can give you instructions on how to disassemble:
First , turn of both hot and cold water off beneath the sink.
Pop the cap off the top of the stem with a screw driver or knife, etc. You'll see a screw which must be removed to lift the handle off. Once the handle is off, you'll need to use a adjustable wrench or slip-joint pliers to remove the retaining nut. You will see one or more o-rings which must also be replaced. Be sure to lubricate them when reassembling.
Once the retaining nut and o-rings are off, you can use a pair of pliers to lift out the old cartridge. Please be sure to take note of the direction of the notch at the top of the stem. Mark it if you have to. When reassembling, be sure the notch is lined up in the same direction it was when uninstalling.
Reinassemble in reverse order.
Hope this helps, if it does, please place a vote or comment for me. Thanks,
Handie Andie
Mar 28, 2011 | Blanco Advance BL157-076CR Polished Chrome...
Looking for faucet repair parts for early 1973's american standard 2separate handles
You will need to take those old parts to a store or place that handles Danco replacement parts. I wish I could direct you to a place that would have what your looking for but parts that old are just not out there. The other possibility is to rebuild what you have those old parts a really tough. I have some old stems and handles that you are welcome to just send me some pictures of what you have and we might get lucky. prb@mwii.net
Mar 20, 2011 | American Standard Plumbing
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Shower/tub faucet does not provide cold water, only to warm and hot.
The faucet has a cartridge that is dirty or bad. Turn off water to the house and remove the cartridge. Take it to Lowes or Home Depot and get another replacement. follow the instructions in the package to the tee.
The old cartridge easily pulls out after you pull out on a clip on the top of the internal assembly. Just take the handle off, slip out the chrome sleeve and remove the clip. The cartridge will pull out with minimal force.
Then head to the store!
Oct 13, 2010 | Moen & One Handle Tub & Shower Faucet
How do I set the anti scald valve on my shower Model L82691
This is something that probably can't be done over the fone. You have to have the paperwork in front of you and be able to see it. I know what to do, but couldn't relay it to you so you would understand. The paperwork is important, do you have it? Look up your faucet on the net and see if they have instructions somewhere. Hope this helps.
Sep 05, 2010 | Moen Home
Leaking bathroom faucet
These single handle faucets tend to need the internal "O - rings" changed every couple of years. Find your model # and take it to Home Depot or Lowes or some similar store and find the "kit" compatible with your faucet. Some kits have a cartridge, some have springs, O - rings, etc. The kit will have instructions on how to remove tha old one and install the new one.
May 24, 2010 | Delta Model 470: Signature Kitchen...
Moen bathroom wash basin faucet leak, how to repair , we have a new house, 45 days old, bathroom faucet leaks, how do you replace the washer or whatever it takes to stop leak, there are no apparent ways to...
No warrantee on new home?
No instructions left for ALL fixtures,water heater,heating system etc that where installed???
Go to a plumbing supply store,and see if they can help. Not Home Depot
Mar 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Cold and hot water reversed on a l82694
To reveries the hot and cold water on your moen first you pull off the handle. then the plastic piece with the screw in the center. Then the brass in the center you rotate 180 degrees. Then you water will be the right way.
Or you can go to link below page 4 step 9
http://www.moen.com/shared/pdf/instruction_sheets/ins898d.pdf
Good luck and please rate 5 thumbs for the free answer
Mar 14, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Moen & One Handle Tub & Shower Faucet  Logo
255 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
