Question about Refrigerators
ICE MAKER WONT STOP FILLING CAUSING FLOOD. SERVICE MAN REPLACED THE WATER VALVE AND ICE MAKER. SAME PROBLEM. WATER VALVE REMAINS ENERGIZED CONSTANTLY WHEN ICE MAKER IS SWITCHED ON. GE SXS PSH25MGWA
  • appcare Aug 03, 2010
    I have not found the schematic for this model. The water valve remains energized when the ice maker is switched on. Maybe the ice maker sends a signal to a control before the valve is energized. A dead short in the harness coming off the ice maker is my last guess. thanks Gary
  • 2,272 Answers
Try this; remove the front cover off the icemaker. On the front of the icemaker you should see holes marked with letters. Make a jumper wire about six inches long skin it about ½ inch on each end (make sure the wire is well insulated). Place one end of the wire in the hole marked L and the other in the hole marked V. This should energize the water valve and run water. Once the water starts running pull the jumper wire out, the water should stop when you pull the wire out. If the water continues to run after you remove the jumper wire the water valve is bad. If the water stops when you pull the wire out, repeat the test. If the water stops each time you remove the wire the motor module is bad.
Recheck the water inlet valve is it for your unit or bit small or big or compatible or cracked valve. Check. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 03, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the water supply valve has already been checked and replaced for a good water flow and still the issue is not resolved then remove the ice bin. Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    Rylee, I did not realize the auger motor was hooked to the water fill valve in any way. The motor works. Can it still send voltage to the fill valve. thanks, gary
  • Rylee Smith
    Rylee Smith Aug 03, 2010
    Usually the issue is with the fill valve only, are you sure the part that was replace was fine.
Why did ice maker flood, then stop getting water?
The flooding was the water control valve letting you know it was about to fail. Now, it has failed closed. The failure could have been caused by buildup of mineral deposits from the water source.
Mar 22, 2016 | Refrigerators
Ge smartwater plus
The problem would not be from your water filter. The water is controlled by the dual water valve inteh back of the fridge. The water valve will most likely need to be replaced. It's possible that a small piece of debris found it's way to the ice maker water valve after disturbing the filter. It's also possible that the ice maker is at fault too, causing the valve to stay energized too long. Although if the valve stays energized too long it will eventually burn out. You can try unplugging the 2 wire plug to the ice maker valve to see if the problem stops first, if not than you will need to replace the water valve unit. Pleazer Appliance...
Sep 02, 2014 | GE Profile PSW26P Stainless Steel Side by...
Ice maker won't stop filling
The ice maker it self is what powers up the water valve after every ice harvest. You have a bad ice maker or the wires shorted somewhere in the harness.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 30, 2013 | Maytag Refrigerators
Kenmore elite, can hear water running for ice maker constantly as of yesterday
Well if the water was constantly running into the icemaker, it would be consequently over filling and spilling out through the unit doors onto your floor. The icemaker can be making a whirling sound, which typically means the ejector arm is stuck, most likely due to a failed thermostat or heater in the ice maker itself. If the water valve is stuck and truly is spilling everwhere in your unit, the problem could be caused by a stuck module contact in the ice maker, or a defective water valve. I guess the best thing to do is to isolate the problem, define where exactly you are hearing the noise. Icemaker assembly, or water valve? If the water valve is sticking open, identify which side of the water valve solonoid is making noise, then check the incoming line voltage to the unit with a meter. If there is 110v approximately coming into the valve, replace the ice maker module. If there is no voltage coming into the unit but it remains on, turn off the water supply and replace the valve. Some high end refrigerators use a relay board to activate the water valve.. in this case you'll have to identify the correct relay for the water valve and make sure that its not sticking closed or malfunctioning, if this is truly your problem with the unit.
Dec 24, 2012 | Refrigerators
I have an admiral American fridge freezer. The ice maker is continuously leaking water if the power is switched on as though a switched on. How can I stop the water ?
To verify if its the valve or the ice maker the easiest way would be to unplug the machine and then turn the water on. If the water stops, then the ice maker is bad and is continuously applying power to the valve causing the flood problem and should be changed. If the water keeps on coming out then the valve is bad and stuck open and should be changed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stopped making ice
If ice maker is not filling with water then fill with tap water and allow to freeze. If ice maker cycles and then does not refill then this points to water control valve. If that happens replace water control valve. Ifice maker does nothing but freeze water to ice then the ice maker will need replaced or parts causing problem fixed. Please call Sub Zero at 1-800-222-7820 and they will refer you to one of their six authorized parts and service centers. Thank You, Sea Breeze
Nov 24, 2011 | Sub-Zero 690 Side by Side Refrigerator
Ice maker has stopped making ice. Infa-red light on inside doesn't seem to be working
One of the causes of ice maker not producing ice is a bad solenoid valve allowing water to pass by and causing the water line to freeze inside the freezer. In other words, if the valve is not holding very well, it will allow water to pass in the line that supplies water to the ice maker. A small drip will ensue and slowly freeze in the line and eventually turn into an ice plug that will prevent water from filling the ice tray. Thawing out the freezer will not solve the problem, you will have to replace the solenoid valve.
P.S.Test the solenoid valve coil and disconnect the line from the valve to verify that it is not allowing water to pass when not energized. Test the infra red module according the manufacturer's instructions if you have them at hand. If the solenoid valve is good and the infrared sensor system is bad , replace it (Infrared system) . The ice maker should be the last part to consider for replacement at this time.
May 06, 2011 | Refrigerators
Thanks for being there. I bought a Whirpool refrid/ freezer on top from a friend and the water pump behind ans at the back of the unit was broken. I had a repair man replace the water pump. What happens is...
If your ice maker was leaking before and after the valve replacement, it is likely the ice maker that is at fault. The ice maker energizes the water solenoid, its not a pump, which then opens to allow the pressurized water flow up to the ice maker. If the valve solenoid has been replaced, the culprit is likely the ice maker itself. The valve should only be open for about 7-9 seconds, but if the ice maker motor is slow, or if there is some other malfunction with the ice maker, it will energize the valve for too long, causing it to then overflow. It could also be a hairline crack in the ice maker mold that is causing it to leak.
Oct 13, 2010 | Whirlpool Refrigerators
Subzero freezer with ice maker. Ice melts and refreezes, into blocks of ice. What could be causing this?
Good day,
In most cases it is the water valve that feeds water to the ice maker well. The valve is energized by the ice maker to fill for 7 seconds and then shut off promptly.
The valve will many times dribble water into the well after shut off, causing an overflow problem.
The fix is a new water valve kit.
The only other possibility is the freezer temperature going above freezing from time to time, but is a rare problem.
Mar 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
