Question about Tetra Plumbing
Pump won't start until I turn the wheel manually thanks John n
  • 30 Answers
Start windings are not being energized, possibly the centrifugal switch or the capacitor
Posted on Aug 26, 2010
Won t turn
Hello John, You need to push the silver button on the machine bed and turn the hand wheel in the reverse direction of rotation until it clicks. Good luck.
Mar 13, 2014 | Consew Sewing Machines
John deere l130
There's a gear on the end of the steering column that's broken or the roll pin used to hold it on is sheared.
Jul 18, 2013 | Garden
Stuck eldorado key in DTS ignition now car won't start
Make sure your steering wheel isn't locked. Sometimes a key won't turn until you jiggle the wheel while trying to turn the key.
Aug 21, 2012 | 2004 Cadillac DeVille DTS
How do you unlock a sony ericsson f305?
Can't find how to send you a message so thought I would post on your question sorry about this I have gained a karcher hd6/13c Resealed cylinder head only the 3 plungers And the 3 seals on thrust guidance Runs ok when reassembled but when you stop and try to restart washing motor won't turn pump. If you turn motor fan on top it's eay to turn then it will work again until you stop again Had motor running fine without pump attached Got a drawing of pump assy 01060320 Can't remove No 24 over flow valve 45910380 No 11 drain plug. 41320070 Thanks for any help John
Feb 28, 2012 | Cell Phones
Steering Wheel will turn when mowing. Trying to get steering wheel off as given in the John Deer Manual, but steering wheel frozen and won't budge. What else can be done to remove the steering wheel...
If you have the main nut removed, you can give the steering shaft a few shots of penetrating oil like Liquid Wrench or PB Blaster (available at auto parts stores). After lubing, let it soak at least a few hours. 24 is good. You may have to get one of those cheap "gear pullers" from like the Harbor Freight store to finally pull it off though.
Aug 13, 2011 | John Deere Garden
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Feb 20, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Plumbing Logo
57 people viewed this question
Top Tetra Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Tetra Plumbing Expert? Answer questions, earn points and help others
