Question about Kenmore 51lb. Clear Ice Maker
I have a kenmore elite under the counter ice maker that quit making ice. It was making ice, we ran the cleaning solution through and now it does not make ice
  • 62 Answers
SOURCE: Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Posted on Sep 06, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
  • 11 Answers
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Posted on Mar 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
TheMobilian
  • 8220 Answers
SOURCE: we have a kenmore elite
Nickle guard is what you should use. Also you should clean around the compressor. Blow out the condenser. I have a service manual for you:
CLEAR ICE MAKER TECH MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 26, 2011
My Kenmore Elite 3 cycle under counter ice maker has stopped making ice
check the filter when was it changed? is the water turned off call sears for help
May 02, 2016 | Kenmore Refrigerators
Kenmore Elite fridge Ice Maker quit spitting out ice. There are ice cubes in the maker, but it wont release them to the bin
One thing you can do is clean up the condenser coils, the toe kick plate, and the area around the compressor to where the air flows better and it might start working.Other than that your ice mold thermostat inside the ice maker itself could be bad. They are not to hard to replace on modular type ice makers: themobilian_2492.jpg
Jun 24, 2011 | Kenmore Refrigerators
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Jul 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Will not make Ice
You need to relace the control board its easy to change but very difficul to get to the top has to be pulled off.
Mar 25, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite 106.54619300 Ice maker just stopped working
sounds like the moter is burnt out and you need to replace ice maker try ebay
Apr 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 51lb. Clear Ice Maker Logo
525 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
