Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Picture is dark. I've consulted manual and tried suggestions
    Problem Solver:
  • 11 Answers
Have been fighting a dark screen almos impossible to see dark scenes
i found this from another person
the mirror has dust on it easy fix
remove front of screen by removing screws around the top and sides of the back don't forget to pop off the bottom cover in the front it just pulls off
then remove center cover screws
i could not disconnect the front electrical plug but it has enough slack to lift and then tip the front screen down to the floor
it will be obvious on the mirrors there is a big one it wasn't to dirty
lean in and look down there is a small mirror and lens they were filthy
there is a piece of foam trying to keep the dust out it was sucked backed so dust could get in
clean with windex and paper towels cloth didn't work
good luck
Posted on Dec 16, 2008
    Scholar:
  • 186 Answers
Is it dark even with the menu settings up high? Is it dark even in the menu settings? It could either be a dark signal input OR Dim light source. Depending on model, if it's LCD or DLP based, you probably need a new bulb. If it's CRT based, you can bring them back to life with a simple adjustment. If it's a CRT (depending on model) the adjustment is either on the back, or on the front behind the covers. There then will be a plastic adjusting screw. BE CAREFUL, there is high voltage back there. You want the TV on and with the menu settings of brightness and contrast all the way up for this part. With a second person there to help spot (if controls are on the back) bring the screen adjustment screw slowly up. Depending again on model, their might be one, their might be three that say screen. Adjust them up until a little brighter then desired but not past the horizontal retrace lines. Lot of information, but really it's an easy fix to get a few more years out of any tube tv that's worn and keep them out of the landfills.
Posted on Apr 25, 2008
How to fix if all channels getting dark
Hi Beckham,
By channels getting dark if you mean the picture brightness getting low, please try increasing first the brightness and then if necessary the backlight level. If this does not work, please consult a good TV tech.
Nov 24, 2015 | Televison & Video
How do I lighten a dark picture
Hi Richard,
Please try reducing the contrast a little and increasing the brightness till the dark shots are clear. Please also check the back light setting. It should not be too low.This should make all the dark scenes clearly visible if it only a setting problem. In case the overall brightness has reduced, please consult a local TV Tech.
Aug 11, 2015 | Sharp Aquos Televison & Video
Phillips 47PFL422D/37 I've had the tv about 6 years with no trouble. But now the picture is to dark to watch it also pulses. I've tried to unplug it and plug it back in I get a picture for
First, average life on these sets is about 3 to 4 years at best and only boards are sold so even if you can pin point the board (no individual parts are sold) it is likely if will not get fixed and doing so is a bad investment as all the boards are now old.
Dec 04, 2012 | Televison & Video
Very dark picture on TV
Try restoring all factory settings. On your remote, press the reset button twice. If that doesn't correct it, then you'll probably need a repair technician. For more info, consult your owners manual, which is also available at
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fe26abca0a54ad7cbe4ba91bb243a7c2&q=Sanyo+DS31590
Jul 27, 2008 | Sanyo DS31590 31" TV
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
224 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
