Question about Kenmore Refrigerators
Kenmore Elite 106.57719701 side by side. PF display cannot reset. Beeps every 5 min. and making me nuts.
  • 146 Answers
SOURCE: kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Posted on Dec 24, 2007
jsrock516
  • 5911 Answers
SOURCE: F-5 error code on Kenmore elite HE3 45872
Click on the following link for a full explanation of the "F05" error code:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
This is not a difficult repair. The error indicates a failure of the heating circuit. If you are not sure of how to diagnose this yourself, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Posted on Jun 12, 2008
22yooper
  • 828 Answers
SOURCE: KENMORE ELITE REFRIGERATOR MODLE #106.53606201
Compressor is cycling on the overload protector. If refrigerator is over five years old the warranty may be expired. I which case I never recommend replacing the compressor if the customer is to bear the full expense.
Posted on Jul 05, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore Elite dryer shows a flashing PF
pf,,power failer...just unplug for 30 seconds,,,
Posted on Dec 31, 2008
  • 672 Answers
SOURCE: kenmore 106 89482995- How to replace water pump?
Access will be from the rear at bottom. Pump found at Sears website at this link. Love those helpful service people !! link is long, but it works. i used copy and paste http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=10689482995&productCategoryId=0164160&brandId=0582&modelName=AUTOMATIC-ICE-MAKER&diagramPageId=00003&componentDescription=PUMP&documentId=P0306093&backToLink=Return to Sub Components list
Posted on Jul 01, 2009
Mi secadora electrica oasis kenmore elite aparece un codigo PF que significa eso como puedo resolverlo
PF means power Failure unplug hold the cancel button for 3-5 seconds if the pf doesnt disappear then unplug the unit for 7 minutes this will make the control reset on the board if the pf still doesnt fade then you would have a control issue and most likely have to replace the control or call a technician if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Feb 26, 2011 | Kenmore Elite Oasis 6809 Electric Dryer
We just replaced the power cord and outlet for a Kenmore Elite HE3 dryer and now it will not go on. I flipped the circuit breaker on and it said PF and now I get nothing.
PF error = Power Failure - error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Here is a site to double check the wiring:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Good Luck Tim
Nov 28, 2010 | Kenmore Elite HE4 Electric Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Digital display
PF means Power Failure. Check the breaker in your breaker box. The dryer uses 2 breakers that are put together. Reset the breakers to see if the problem gets fixed.
May 13, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 67082 "PF" power failure code
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Refrigerators Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
