Question about Maytag MDE5500AYW Electric Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Posted on Aug 04, 2010
  • Jeff Meier Dec 10, 2012
    How do I pull the door?
    New Friend:
Thank you for this information. Loose screws and one missing. My dryer is now quiet
Posted on Dec 15, 2015
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Neptune dryer makes a banging noise on the left side each time the drum rotates
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | Maytag MDE9700AYM Electric Dryer
Dryer is making a loud banging noise.
there are bushings or rollers at the front of the drum that do wear out this will cause the thumping as it turns. A local appliance repair place may be able to source out new guides for you.
Feb 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is making a loud banging noise on the left side of sounds like something is rubbing in it. Any idea what it might be, and how to fix it?
heatman101
76fg
Jun 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
THE DRYER IS MAKING A NOISE ON THE LEFT SIDE WHEN IT IS ON
heatman101
uio4
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Banging noise as dryer spins, wore hole in side of dryer
I need to know your make and model number in order to give proper advice. Joe
Nov 07, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Loud noise
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Nov 02, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE5500AYW Electric Dryer Logo
2,056 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
