Question about Braun Health & Beauty
On activator mod.8585 procedure to remove side covers to replace comp, head assembly my e mail ,,wcherwonka@yahoo.ca Thanx Walter..
  • Braun Master
  • 1,626 Answers
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will find the replacement part at shaveroutlet.com
Posted on Aug 06, 2010
Braun activator 8585 change the foil
braun series 5 combi 51S outer foil and cutter replacement pack (Formerly 8000 360 Complete Or Activator) for men electric shaver braun 8585 replacement parts.
Jul 30, 2013 | Braun 8585 Electric Shaver
I need take out cilinder head from nissan 1985 2.4 becuse the head gasket are burne out
Check this about Cylinder Head Cover - REMOVAL & INSTALLATION procedure...
1. Remove the air cleaner assembly.
2. Disconnect the PCV hose(s) from the cylinder head cover.
3. Remove the nuts and washers. Lift the cover off the cylinder head. Cover the oil return hole in the head to prevent dirt or objects from falling in. Remove the gasket.
To install:
4. Replace the cover gasket if it shows any signs of damage, breaks or cracking. Tighten the nuts evenly, reconnect the PCV hose and install the air cleaner assembly.
continue...
Apr 13, 2011 | Nissan Pickup Cars & Trucks
I am trying to remove the pivoting head from my Braun 8585 ... removed screen and cutters and the two screws under the cutters but cannot see what else to do to get the head removed
The swivel frame can not alone be removed from the shaver. It is part of a component called a 'drive unit' which icludes the motor. You will find a disassembly video at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Mar 17, 2011 | Braun 8585 Electric Shaver
I need a replacement battery for my BRAUN 8585 shaver. When (if) I manage to lacate a battery I will need instructions on how to replace the battery.
You will find compatible battery type at shaveroutlet.com. See link below. Be sure to read the NOTE on the page concerning installation
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
If you are not able to solder in new batteries, you may want to simply buy the circuit board that includes the batteries. See link below
http://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
To disassemble the shaver, first remove the 'cap' on the bottom that surrounds the hole where the cord plugs in by gently prying it off with the tip of a small flat screwdriver or similar object. Once removed, the side grips simply pull off revealing 4 screws on the back. Remove the 4 screws to remove the back cover and access the insides. Reassemble in reverse order.
Aug 20, 2010 | Braun 8585 Electric Shaver
I've connected it to 115v with cable from old Braun and probably burned out fuse or rectifier. How I could take apart the shaver?
To open the shaver body on model 8585, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will probably need to replace the circuit board you will find a replacement circuit board for model 8585 at shaveroutlet.com. See link below
Jul 31, 2010 | Braun 8585 Electric Shaver
How do I open a Braun 8585 shaver to replace the battery?
You will find batteries at shaveroutlet.com. See link below
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 13, 2010 | Braun 8585 Electric Shaver
I have dropped my braun 8585 although in a bag. It is charged but just no longer works. I thought that taking the head off might reveal a broken connection but could not find a way further than removing...
Replacement parts can be found at shaveroutlet.com
Jun 27, 2010 | Braun 8585 Electric Shaver
Loud rattling noise
Most likely, the drive unit needs replacing. You will find a drive unit at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
To replace you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out
May 10, 2010 | Braun 8585 Electric Shaver
Braun Drive Unit 7030244
To open the shaver, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
You will find a replacement drive unit for model 8585 at shaveroutlet.com. See link below
Apr 07, 2010 | Braun 8585 Electric Shaver
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
