Question about Freezers
The first led light of my samsung srl3616b fridge is flashing continuosly and the fridge is not working. What does the single flashing led mean?
2 Suggested Answers
SOURCE: Samsung RSA1WTMH i just blew
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Posted on Oct 22, 2010
After a power outage my Samsung SRS580DHLS is displaying and flashing SE? What does this code mean and how do I fix it? Rirht now the control panel only displays SE and does not respond to any presses
Your control board is reacting to a surge in power. Unplug the unit for 5 minutes then replug and follow normal starting procedures. If that does not work think about buying a new unit.
Oct 11, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
Help with Light for Fridge RS265TD RS
Most refrigerators have a switch somewhere. look for a little white triangle either at the top or bottom. there may be a push button style somewhere along the upper hinge cover.
Nov 05, 2013 | Samsung RS265TD 26 cu. ft. Side by Side...
I have a samsung fridge freezer upright i cannot get the lights on the top to stop flashing and there is a spasmodict motor sound keeps striking up and every thing in the fridge at the top will freeze ?
hi it will probally be the lower damper motor .. guy on you tube will be able to help , his email address is under some of the videos .. email him ..
Jan 31, 2011 | Samsung Freezers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
Angus
Sep 21, 2010 | Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Freezers Logo
56 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
