Question about ITT Jabsco Jabsco 135 Sl Remote Control Searchlight Replacement Bulb
I have a jabsco search light model 60080, the light turns on and moves up and down but will not go from side to side ,it only makes a clicking sound, would this be a control problem or the light itself. John
  • jjcloud Aug 03, 2010
    I have a search light on my boat it turns on and moves up amnd down but will not go side to side, I took the light off and the gears looked good any Ideas?
    Genius:
  • 1,456 Answers
This is a problem with the control,the neck is not making the right contact, it is probably stuck
What you should do is to open the casing and try to re-adjust the neck of the searchlight,it should make a clicking sound if it is properly adjusted
Posted on Aug 03, 2010
  • 6,993 Answers
the problem should be from the control panel. Something might also be preventing it from moving side to side. Open up the search light and check the neck part that moves side to side and see if its free or check whatever that is disturbing it from moving side to side.
I believe something is preventing it, that's why its making the clicking sound.
Good luck.
JABSCO ELECTRIC TOILET HAS JUST SUDDENLY STOPPED WORKING ?
Contact your local Jabsco retailer or their technical site here: Jabsco How to Videos Jabsco Tech
May 22, 2017 | RVs
Jabsco model 37010-0090 electric head. sometimes no motor run or flush when button pressed. By turning slotted shaft on end of motor , button then activates motor and flushes.
Sounds like the motor commutator and brushes need some attention. Not a difficult job if you have been there before but it can be tricky for a novice.
Oct 14, 2013 | ITT Jabsco Manual Marine Toilet Compact...
Jabsco 3270-200 repair manual
go on line --google --and type in jabsco water pumps repair manual. If you find a free down load select the workshop manual and you will get what you want
Apr 20, 2013 | Jabsco Boating
Jabsco 146sl repair
I am looking for a manual for a jabsco 60080-0012?
Jan 19, 2012 | Jabsco 60080 0012 Marine 146sl Remote...
I have a singer 6106 but no manual. When I press the foot the needle doesn't move although the outer wheel on the right hand side of the machine goes round. If I move the inner wheel on the right the...
go to http://www.singerco.com/accessories/instruction-manuals and type in your model number, then click "search" to locate the manual for this machine.
Sounds like the clutch is disengaged on your flywheel. Hold the outside of it and turn the inside bit away from you to reengage it.
May 28, 2011 | Sewing Machines
Light turns on and moves up and down but will not go from side to side only clicks, I removed the light and the gears looked good. could it be the control itself?
Chances are that it may be a ceased motor assy.
I had same problem & solved it by replacing motor assy.
Suggest unwire it & remove from unit and apply 12v to terminals (either way round)
If the gear wheel does not turn slowly then that is where your ploblem lies.
Replacement motor not excessively expensive.
Aug 03, 2010 | ITT Jabsco Jabsco 135 Sl Remote Control...
Spotlight will not move in one direction
Most spot lights have a collar at the base that can be loosen to get the light to move left or right, then retighten.
Dec 04, 2009 | NRS By Itt Jabsco"
I have a jabsco 8'' searchlight, it slews however the light went out, is this replaceable or is a whole new unit needed.
Seems like it MUST be replaceable. Look it up on the net. http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS331&=&q=jabsco+searchlight+parts&aq=1&oq=jabsco+searchlight
Jun 16, 2009 | Boating
ITT Jabsco Jabsco 135 Sl Remote Control Searchlight Replacement Bulb Logo
161 people viewed this question
Top ITT Jabsco Boating Experts
Mike
Steve
Steve
Bill Boyd
Are you an ITT Jabsco Boating Expert? Answer questions, earn points and help others
