Question about Keurig B60 Coffee Maker
Keurig B2000 only dispensing 1/8 cup of water
Kcup holder and tip have all been cleaned and look to be in good shape.
Push button with no k cup in to see if just hot water will come through. After pushing button it takes about 25 seconds for first drip of water to enter the cup. During this time the engine in the k cup area is straining and surging power (my lights dim sometimes). After 25 seconds- spurts of water come out but never a steady stream and in the end we have about 1/8 to 1/4 c. water in the cup (it is hot though)!!
After trying this process for 3 or 4 times all the lights start to blink on the machine and you can not operate the machine again unless you turn if off then back on again. (Signal to me that something is not right.)
All fuses look to be in good order and plugged in, no apparent damage from shipping or something that might have gotten loose.
From the people I have had look at it they seem to think maybe the valve between the hot h2o tank and the k-cup is bad? We really do not know though.
  • jdeross Jan 19, 2009
    I have tge same problem. Did you fix yours?
  • 6 Answers
Call keurig....they will replace in a flash!
Posted on Sep 17, 2010
Hi If you are still having problems with this machine Email me at kinshella@shaw.ca
Posted on Sep 03, 2008
How to fix a Keurig coffee maker?
Most of them have recalls check your recall list for Keurig. I no I had one....
Mar 16, 2016 | Keurig Coffee Makers & Espresso Machines
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
Cup not filling up
There are 3 needles on the underside of the lid and one on the bottom of the kcup holder. Using a thin "uncoated" paper clip, straighten the clip and insert it into the hollow needles and then run a 4oz cup of hot water (NO Kcup}. Repeat until NO more grounds are dispensed. Dave
Mar 04, 2014 | KUERIG Keurig Platinum B70 Brewing System
No water coming out of keurig
It could be that your Keurig's water line is clogged. To flush out debris, run water through your brewer a few times without a K-Cup. I'd recommend this step if your Keurig is brewing some coffee, just not a full cup.
Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle.
Still won't brew? Try the burp and slap method: unplug, remove water reservoir, turn your Keurig over and spank its bottom.
If you've given your Keurig a good spanking and it still won't behave, contact Keurig (866-901-BREW) for help.
Apr 12, 2013 | Keurig Coffee Makers & Espresso Machines
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
Water flows through fine without a kcup, but only trickles out to fill a 1/3 cup with kcup. what should i do? thank you.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 05, 2011 | Keurig Ultra In Home Single Cup Brewer...
My keurig will not brew. It says it is brewing but the water level is not going down and it is not brewing
heatman101
Nov 11, 2010 | Keurig B60 Coffee Maker
My keurig only dispenses half of a cup of coffee. Half the water comes through the kcup and the other half is despensed back into the water reservoir
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Nov 03, 2010 | Keurig B60 Coffee Maker
Keurig B60
Check the needle inside the k-cup holder to ensure it is not clogged. You can completely remove the k-cup holder by pushing up from the bottom (where it dispenses into your coffee cup). Then rinse it out with hot water using your kitchen sink sprayer. The manufacturer also recommends inserting the tip of a small paper clip into the needle to push out any debris if needed. Then replace the k-cup holder by aligning the arrows and snapping it back into place. Next try to brew your regular cup of coffee and see if that fixed the problem. Hope that worked for you...Best of luck!
Aug 29, 2009 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
1,435 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
