Question about Philips Magnavox 15MF400T 15 in. LCD Television
I am looking for the code to put into a Direct TV remote to operate a Magnavox TV model 15MF400T/37 and a Panasonic TV model PV-C2020.
  • herb_wolter Aug 04, 2010
    I need to find the correct TV remote codes to program into my Direct TV remotes to operate a Panasonic TV VCR combo model PV-C2020 and a Magnavox 15MF400T/37 15 in. flat screen TV/PC monitor. I have tried more than a half dozen codes supplied by Direct TV technical support for each of the models.
  • 4,102 Answers
Hi please give me the make and model of remote if their is nothing written on the remote about make and model have a look under the batteries then i can give you the instructions on the code or how to scan for the code manually
let me know then i can assist you further ok
if the make is direct have a look for model on sticker under battery if no their let me know how long you have had the remote then i should be able to figure out what model it is
Posted on Aug 04, 2010
  • 4,472 Answers
Http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380036#h:620.612
Follow that link and you can do a remote code lookup for your direct tv remote. I used it and it came up with this code for the magnavox: 11454*
and this code for the panasonic: 10051
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • If you need further assistance please let me know.
    Thank you and good luck,
    Lee
    Posted on Aug 03, 2010
    • 1 more comment
      I tried the the codes. They did not work, neither did a half dozen other numbers for each suggested by Direct TV technical support. I do not believe that Direct TV has the information. Do you have any other sources?
      I tried the the codes. They did not work, neither did a half dozen other numbers for each model suggested by Direct TV technical support. I do not believe that Direct TV has the information. Do you have any other sources?
    Magnavox tv code
    Which brand remote control did you bought. It might haven't any setup codes in its memory, to match with Magnavox. 017,021,022,075,081,082 087,088,089,090,101,102 143,144,145,146,147,196,197. These are the setup codes to check with Magnavox. If you wish to get more, check this llink.
    http://electrohelponline.blogspot.com/
    Jun 04, 2013 | Televison & Video
    I am looking for manual for panasonic tv and vcr comb model # pv-c2020 made in jan 2000
    You can download copy of the user manual for this unit from this link , just click HERE.
    Sep 02, 2011 | Panasonic PV-C2020 20 in. Combo
    What is the TV remote controller code for a Panasonic Model # PV-C1320?
    Hello
    Universal remote codes for Panasonic TV/VCR combo are:-
    0374 0381
    Direct Code Entry
    1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
    3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
    4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Mar 04, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
    Need Universal remote code for Magnavox 15MF400T/37
    these are the codes associated with Radio Shack's line of remotes:
    One for All Universal (Radio Shack)
    0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
    And I was also able to find these:
    UNIVERSAL REMOTE CONTROL CODE LIST for TVs
    MAGNAVOX
    002 009 109 118 209 309 402 408 502 508 510 807 914 917
    Jan 24, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
    IR reciever in my Magnavox 15MF400T/37 does not respond to the remote.
    You basically have to take the tv apart backward to get to the front. Start with the back panel unscrew all the screws. Then you will see the internals. IR sensor should be botton left side if you looking down on it.
    Sep 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
    Looking for tv code
    Magnavox 0054, 0030, 0706, 0020, 0187,
    0179, 0024, 0096
    May 23, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
    Need Help
    check the cable connecting to the System unit!, it could have loosen up!
    tighten it
    Feb 15, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
    Universal Remote Codes
    I just programmed my comcast remote today and the codes in the manual work fine. I was lucky, the first one as the one I needed. Good luck.
    11454, 10054, 10030, 10706, 10187, 10386,10802,11198,11254,11963,11990.
    Jan 17, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
    Philips Magnavox 15MF400T 15 in. LCD Television Logo
    73 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
