Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My 52 in rca is sparking at a tube where the main red wire that powers the tv is there anyway of fixing it or is it pooched.
  • RCA Master
  • 8,617 Answers
You can replace the CRT ( TUBE) which has the HV wire installed in it. You can get replacement CRTs from www.tvrepairworld.com
Posted on Aug 04, 2010
Tv went off and won't come back on.
the arcing sound is some kind of high voltage leak, which will shut down the tv. pull the speaker grill off and the access board, look at the 3 picture tubes, turn the set on you will see where the leak is, it's usually the high voltage splitter, which has a high voltage wire going into it and 3 high voltage wires coming out going to the picture tubes, if it arcs from the splitter you need to change it, if it arcs from one of the picture tube wires you need to pull the tube out and fix the high voltage leak, and possibly a cooling fluid leak caused it, not an easy reapir, you probably need a repairman.
Sep 08, 2009 | RCA P52926 52" Rear Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Apr 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red screen and only red bulb powers on.
The red tube and the red crt board sound like the problem. these would be the first thing that needs to replace 250 for tube +50 for crt board. + labor about 300 to 500 to repair
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52" projection tv...d52w20
You could have a bad red tube or the socket on the tube may be bad; completely different from convergence
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Rca Hd52w58 electrical short
Just replace it... it is called the High Voltage Splitter. One red wire is the high voltage input from the flyback (high voltage) transformer, 3 red wires are the high voltage outputs that go to the 3 picture tubes and the red wire by itself is the focus wire going to the focus block. Does your splitter have a small PC board on the side of it? What is the exact model or chassis number of your set? With that info I can give you the RCA part number of the splitter which makes ordering it much easier.
Aug 23, 2007 | RCA HD52W58 52" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
