Question about Kyocera KM-1505 Copier
Konica 7022 copier f 35-3 code - Kyocera KM-1505 Copier
I have put in new toner yet there is still 'add toner' message on the screen.
What do I do? Please help me.
Posted on Nov 22, 2010
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: code 35-02 ( konica 3331 )
problem with fuser, check thermistor, thermofuse or lamp
Posted on Oct 06, 2008
firecontrol7
  • 6696 Answers
SOURCE: Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 13, 2009
  • 1297 Answers
SOURCE: i have a konica 7022, it says call for service
Fixing upper roller low temperature error.Verify the continuity the heater lamps and remove and clean the thermofuse.If the thermofuse not working change it.
Posted on Sep 26, 2009
saxmansaxman
  • 177 Answers
SOURCE: Konica 7022 copier at start up says call service
The thermistor TH1 on the fuser unit is coming up as faulty this will cause your f-35-3 error you can reset it in service mode 25 dip sw3 0 to 1 however i do not do this as there is an issue i would replace both thermistors and look at the fuser unit for wear if in bad shape replace the fuser unit assembly
Posted on Feb 02, 2011
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Why error code F-35-3"?"
http://officeimagingsystems.com/id169.html take a look at here
May 24, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
Konica 7022 copier at start up says call service and shows F-35-3
Jan 22, 2011 | Konica Minolta Office Equipment & Supplies
I have a konica 7022, it says call for service code F-35-3. what's wrong with it. please help me.
Sep 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code f-35-8
Ensure there is no jam in the fusing unit. Turn copier off. Turn the copier back on while pressing down on the 2 and 5 keys. Select 1, the software switch settings. Using the arrows on the touchscreen, select dipswitch 3-1. Touch the off key. Press return, then turn the copier off and back on. If the code returns, you may have to replace the temperature sensors in the fusing unit.
May 19, 2008 | Office Equipment & Supplies
Kyocera KM-1505 Copier Logo
343 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
