Question about Miele Novotronic W1918A Front Load Washer
Miele Novotronic W1918 Front Load Washer made in Germany. Machine is running on a new double receptacle box. There is power as the ON light is lit but it will not begin washing. Have tried unplugging it to see if that works but nothing happens. It displays 0 minutes on the screen. It also says 'finish' on the programme sequence. The DELAY button seems to not budge at all though, neither in nor out.
5 Suggested Answers
SOURCE: need the operation manual
Here is a link for your manual.
mielemanuals
verno
Posted on Apr 07, 2009
  • 123 Answers
SOURCE: miele novotronic w1918 wiring schematics
hi there ....the wiring schemematics can be obtained from meile with no problem .....if you can tell me what area in uk youn reside i can advise you where to obtain your diagrams
Sir Galahad
Posted on Aug 12, 2009
  • 1527 Answers
SOURCE: Fuse Box
there will be a glass fuse on the power board of the washer it might have cover over it good luck
shaun
Posted on Aug 15, 2009
rickead1
  • 1998 Answers
SOURCE: Water leak
first you should open the unit and find out if the leak is coming from a hose or the pump or maybe a crack in the tub
Posted on Jul 25, 2010
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
Novotronic washer w1918 jumps violently when transitioning from main wash to rinse 1-2 with 21 minutes to go to end of wash cycle
If the problem is consistent, FIRST check to make your machine is level. Also try cleaning the machine out with no clothes in it using white vinegar on a hot wash. If you're having a problem with high speed spin with NO load in it, it could be shaft/bearing related which would probably be too expensive to fix. Otherwise you could simply just be adding loads incorrectly or overloading it.
May 19, 2014 | Miele Novotronic W1918A Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Water leak
Jul 25, 2010 | Miele Novotronic W1918A Front Load Washer
My miele machine tends to bleach my clothes.
I would run a few cycles with just water added to the bleach dispenser, clean it out, and see if that helps.
Nov 06, 2009 | Miele Novotronic Premier 500 Front Load...
Fuse Box
shaun
Aug 14, 2009 | Miele Novotronic W1918A Front Load Washer
Miele novotronic w1918 wiring schematics
Sir Galahad
Aug 12, 2009 | Miele Novotronic W1918A Front Load Washer
"Faucet" light is on during installation of washer
Check the pipes are not kinked up, and pull the machine away from the wall slightly as the pipes can get trapped.
Also, and I only say this as I have been caught out myslf, run the tap to double check the main water is on.
May 23, 2009 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic W1918A Front Load Washer Logo
100 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
