Question about Samsung SPN4235 42 in. Plasma HDTV
When i push the power button on it makes a clicking noise, and i have no picture or sound
    President:
  • 1,099 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Good luck and hope this helpout
Posted on Aug 03, 2010
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Tv wont turn on
I have a Philips 60" Rear Projection, and all of a sudden I have no picture or sound. I push the power button, and all it does is click. It will keep clicking until I turn it off. Anyone seen this problem?
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
When u push the power button the tv tries to turn on, makes 3 switch noises and then the power turns off
this is somtimes a bad power supply or fuse if you have sound it likly and no picture usaly a fuse put this seems pretty much like a power supply issue this regulates power from the wall to each component of the tv like the picture and the souns amp
Dec 20, 2009 | RCA D52W136D 52 in. TV/DVD Combo
Rca 52 inch power light comes on no pic.,shuts off makes noise
I think you have a shorted hori output Transistor NTE2324 if it makes a low squealing sound also ck capacitor 114,120,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and other 2 are 220uf 35v.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help ,help.
On- timer light flashing no picture no sound.
Dec 23, 2006 | JVC AV-32D502 32" TV
Samsung SPN4235 42 in. Plasma HDTV Logo
345 people viewed this question
Jerry Greenberg
Jerry Greenberg
