Question about HP w2207 Monitor
I lost the color blue. Is that a monitor problem, driver problem, or some kind of graphics software problem? And, how do I fix it? This occurred after I unplugged and moved the computer into another room. I've tried to adjust the color but blue does not change or adjust at all.
    President:
  • 2,571 Answers
It may just be the cable, or the connector that attaches to the monitor or pc.
This monitor also had a similar problem, it was connected with a dvi to vga adaptor on another computer. I plugged it straight into the vga socket on this computer and it works fine.
If that is no help, you may need a new monitor
Posted on Aug 03, 2010
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Lost red colors on GM4019E desktop..It's not the monitor because I tried 2 monitors that are working and only on this desktop that the color show greenish..When I start the computer the small...
If 2 monitors are showing the same picture, your graphics card is at fault.
First, Click on my computer - device manager - check there are no alarms shown by the devices in your pc especially the graphics card.
If none, RMB click on your graphics card, select properties and choose the "Roll back Driver" option.
Second, look on the Gateway website, follow links for support/downloads check that you have the latest driver for your graphics card. Also note the make, model and type of your graphics card. You'll need these if it has to be replaced.
If both have been completed, then your graphics card probably needs replacing. I'd try ebay first for a good second hand. You could take this opportunity to upgrade, just make sure you buy on with the correct interface.
Feb 22, 2012 | Gateway GM4019E PC Desktop
I lost the driver and icouldn't find it my os windows xp
kindly find the link below to download your driver
DRIVERS LINK
thanks and regards
kindly rate this solution
Oct 28, 2009 | Power Color Xaber 200 X20L-A1 (32 MB)...
Monitor lost resolution
itz probably corrupted software/driver or graphic adapter..
try reinstalling the drivers..
but 1st open control panel->display->click on the 'Settings' tab->Color Quality= (Highest) 32 bit; Screen Resolution= 1024x768 pixels (atleast)..
..try contacting ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
I CAN'T READ THE BLUE TEXT IN MY E MAILS
If Blue colors display properly in pictures or graphics check the display and size settings of your computer in relation to the size monitor.
If there is a problem with the blue color because of a problem with the monitor you might be able to compensate for it either with controls on the monitor or with the control software of your video card.
Jul 17, 2009 | NEC MultiSync LCD1720M (Black) 17 in. Flat...
1 port works for a short while and the other has lost all red
Have you checked in your control panel wether extended desktop is actually enabled on the second monitor? If it is, then maybe you have set the resolution too high. Try lowering it. If that doesn't help either, please post back here.
For the one without the red, first check all your color settings, then reinstall the graphics driver, and if that doesn't help, try replacing the vga cable, monitor or graphics card with another one.
If that doesn't fix it either, you'll have to post the results back here.
I hope this
Jun 16, 2009 | Pine Technology XFX GEFORCE 7950 GT 512MB...
What is the vga
vga is vidio graphic adapter.
It is software which communicate graphic hardware and operating system.
Jun 13, 2009 | Microsoft Windows XP Professional
Gateway GT5058 Geforce 6100 lost red
yes.. Check to make sure your wires are in good working order, check for loose pins, and make sure there aren't any kinks / tears / breaks in the shielding for the monitor cable.
Also, make sure you have the latest drivers for your graphics card, and that someone hasn't tampered with any color settings on the monitor / graphics setting software (nVidia allows me to adjust color for each individual color... i.e. red, green, blue.. )
Also, i have seen times where KVM's have caused the color to be off. even after removing the monitor from the KVM and testing a new monitor on the KVM, after detaching the KVM, and allowing it to reset (1 minute no power) then reconnecting it with all 4 PC's turned off, the issue went away.
To Recap:
1) Make sure monitor settings are at factory default
2) test the monitor on another PC, if good step 3
3) test different monitor on affected PC, if good, step 4
4) be sure your software settings work for your monitor, and all cables are secure, and free of defects such as kinks, broken shielding, broken wires within the shielding, missing / bent / broken / loose coonector pins.
If all abouve test show the monitor is good on one PC, and bad on another, replace your graphics card to see if this solves the problem, if so, your card may be faulty
May 20, 2009 | Gateway GT5058 Desktop PC
Cannot reset defaults for HP color monitor. No reds, just garrish
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | HP vs19 (Silver) 19" LCD Monitor
HP w2207 Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
