Question about Dewalt Versa Clutch Tek Screw Gun DW268
Can not get the bit out of chuck - Dewalt Versa Clutch Tek Screw Gun DW268
How do I load the drill bits in the keyles chuck of my Metabo impact drill Model SBE 561?
Keyless chucks work one of two ways
1: Simply turn the chuck by hand to loosen or tighten drill bit, once it grips the drill bit you will not be able to turn it anymore
2: Some keyless chucks operate by pulling the chuck back towards the body of the drill, placing the drill bit in and then releasing the chuck back to its original position
Sep 08, 2014 | Drills
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Screwdriver bit is stuck in chuck
Hello, W/D here.
Spray some penetrating oil in the chuck alongside the bit. Work the chuck back and forth, attempting to get a little slack in the chuck. Rapping along the side of the chuck with a plastic hammer will help, but use a regular hammer if you don't have a plastic one, just don't hit quite as hard. Tap the bit to loosen it, and continue to tap along the chuck, working back to the bit every so often. Eventually, the bit will release, and you have already lubricated the jaws of the chuck. Operate the chuck fully once the bit is released to free up the jaws. It will work like new.
Best regards, --W/D--
Mar 07, 2011 | Garden
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
Drill bit stuck in chuck
Grab the bit and see if it will move in or out of the chuck around a half inch. If the bit will not move at all inside the chuck at all. Lock the bit in a vise and strike the chuck with a rubber mallet. This will usually get the bit out.
Jan 18, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How to fix the bit
If your Makita matches the one on the picture, you will need a chuck key to attach a drill bit or tool to the machine's chuck. The chuck key inserts to any of the small holes in the front part of the chuck and at the same time its teeth interlocks with the teeth of the chuck. When turning the chuck key you will widen or loosen the grip of the three jaw pieces, that clamps to your tool or bit. Tighten the chuck key by hand until the chuck grips the bit securely. For safety, unplug the power cord whenever operating the chuck key on the chuck.
Jan 09, 2011 | Makita & 1/2 Inch Drill
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
My rattle gun 18V LXT Impact Driver BTD141 has a double ended Philips stuck in it? how do i get it out?
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Jul 12, 2009 | Drills
BIT FALLS OUT/ WON'T TURN
try pulling the chuck back at the same time turning the bit while installing it should drop into place release the chuck,then make sure the lever just in front of the trigger is switched over to the rite side to use the hammer action.hope this helps
Jun 20, 2009 | Bosch 11236VS Rotary Hammer
Dewalt Versa Clutch Tek Screw Gun DW268 Logo
41 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
