Hello i have a hd50lpw62ayx2 and the color wheel is bad would i be able to fix this myself??
  • 121 Answers
Yes you can do this yourself you can get a color wheel at the sight I posted also installation instructions as well as indexing instructions as well as free online tech support while you are doing the actual install incase you need help. By doing this yourself you will save approx 400.00 on labor alone
http://servicemanuals.vstore.ca/
Posted on Apr 26, 2008
I have a 48 inch rca dlp tv that does nothing except blink green light in front and makes a loud noise no pic no sound. do i need to replace the lamp and the color wheel or juss one of them, or should i...
Hello my friend...
probably you do need to change your color wheel have you change your TV lamp?
here is a website were you can check prices they are really good not to expensive.
and yes i recommend to buy just the parts and not a new TV fix the one that you have
http://www.discount-merchant.com/Factory-Original-Lamps-Bulb-For-your-RCA-Scenium-p/rca-lamp-265866-26591-269343.htm
http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsung-cw-bp96-01579a-enc.htm
the prices may go lower depending on your TV part.
good luck.
Mar 17, 2010 | Televison & Video
WHINING SOUND
More likely it is the color wheel this set uses---it is located inside the optical engine---part number for it:
267888This part is no longer available from RCA but is available on several sites on the internet (google the part number)
The wheel will when going bad sometimes make a fan like noise or even a high pitched whine.
Check out the sites on the net that sell this for price and decide if you want to attempt to replace it or if you have to have a shop do it for you.
Let me know if you have any questions or need advice.
REGARDS, SD TECH
Oct 05, 2009 | Televison & Video
Instructions on How to change an RCA Color Wheel
You can get help at;
They will charge for manuals but they also give on-line tech support free!
Apr 06, 2009 | RCA HD61LPW165 61" Projection HDTV
How to replace rca color wheel
Its fairly easy. Remove the back of the TV. You'll need torx head screwdrivers as RCA uses them exclusively on their TVs. The color wheel is mounted on the light engine to the left of the lamp assembly and has three screws holding it in place. There are also two connectors which have to be undone. You may have to transfer them from the old to the new one. On rare occassions, an alignment of the wheel speed is necessary. If that's the case, you'll need to contact an RCA authorized service center to have this done.
michtech
Feb 14, 2009 | RCA HD61LPW165 61" Projection HDTV
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
I have an RCA model #HD50LPW62AYX2 hdtv/dlp rear-projection set. The picture went out, and we thought it might be the bulb, so replaced it. The picture still will not come on, and there is a loud...
The color wheel can make a whinning sound for sure, However it should not continue to whine after shutting it off. That sounds more like the fan used to cool the lamp, as that will continue to run after the set is shut off. How soon does the whinning start when you push power? Let me know I should be able to help you out. DLPs are my specialty
Mar 26, 2008 | Televison & Video
Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Sounds like you have a bad color wheel assembly which is located in your light engine assembly.
pt#BP96-00250A
Nov 26, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
