Question about Kenmore Washing Machines
What does it mean when the F1 comes up on my Kenmore Elite Oasis HE, model number 2709
  • 119 Answers
Pressure Signal Out-of-Range
F
then 1 flashes when the control detects an
out of range pressure signal.
➔ Check pressure hose connection from tub
to machine/motor control. Is hose pinched
or kinked?
➔ If F then 1 repeats numerous times after
POWER is pressed and the pressure hose
connection is not pinched or kinked,
replace the machine/motor control.
Posted on Aug 04, 2010
Can wash my clothes washer is giving a f1 announcement and stops.is a kenmore elite oasis model 110.27032602 quiet pak 2.thanks
The F1 error code means that the control board has a detected a problem within the control itself and the control board would need to be replaced.
The part number for that control board is W10189966 it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
What does code F1 mean for a Kenmore Elite Oasis model 27032?
Here is a link to some good information on your error code. This should explain the error code you have.
http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
Nov 21, 2010 | Kenmore 27032
Kenmore Elite Oasis 2709 water level problem
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 09, 2010 | Kenmore 4292x Front Load Washer
My Kenmore Elite Oasis HE is flashing a code
sound like the rps kit is required and is time comsuming will have to remove the back and console includes harness and new rps sensor and inset for sensor if not sure if you can perform it would be better to call service tech....must remove from the bottom of the motor location(main drive d/c motor)
Aug 19, 2009 | Kenmore Washing Machines
F1 CODE
http://forum.appliancepartspros.com/washer-repair/7591-kenmore-oasis-f1-code.html try this but I'm sorry to say you will probley need a new computer I had to with my stove pay for the guy to come out then more money for a new computer for the stove, not the answer you wanted but most likely is whats going to have to be done sorry and hope this helps
Jul 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore oasis elite flashes f1 and wont run it's cycle? Can't find my manual.
The F1 error code indicates either that the pressure signal is out of range or the pressure hose is blocked. This would mean that the control board is defective or the pressure hose is pinched or blocked somewhere between the control board & the outer tub. You can check the pressure hose by removing the rear panel & looking where the drain hose is coming out of the back of the cabinet.
Jan 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
