Partation blocked Hello, my ( local disk D) is not accessible it has all my data, it was working untill i make new win xp installation on drive c, fromthis moment every time it show the message drive is not formated do u want to format it thx in advance for ur help Emad
  • 156 Answers
I've used partition magic to recover some pretty messed up drives in my time. I'm not saying its going to work... I"m saying it has for me in the past.
Posted on May 01, 2008
Win xp install problem
According to your problem , the main problem can be of your Hard disk having bad sectors.
This is common problem as the Hard disk goes old.Hard disk having bad sectors can make you lose your data and also it cannot be recovered. So your decision is very right to look for a new Hard disk,this will solve your problem permanently.
Thanks for using Fixya.Have a good day.
Apr 01, 2012 | Computers & Internet
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Unable to see data on Zip Disks
You are saying that you used zip drive in 1998. i want to tell you that in 1998 the processors were of old versions.therefore,you need to install windows 95,only then you will be able to retrieve your data.
As the only reason to be found is that you used win 95 in 1998,now you are using win xp,the files you stored on your drive were only supported by win 95,hence you need to install win 95.
THANK YOU. hope you get a well experience on
Oct 10, 2009 | Iomega Zip 100MB (31714) External ZIP...
My sony laptop with windows xp home media center keeps rebooting
When XP gets into the rebooting mode, you will have to run a chkdsk or do an XP repair. You will not lose your data. But you do need your recovery cd or a WinXP cd.
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type chkdsk C: /R at the prompt in the recovery console.
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
Lastly, your drive can be taken out of the unit and set into an enclosure or adapter. The data can be saved, the your hard drive can be formatted and programs and data reinstalled.
Good Luck,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 10, 2009 | Sony VAIO VGN-NR120E/S Notebook
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Reinstall Windows XP Pro without losing my data
There is a free program that will allow you to view and change your current product key. It is called Magical Jelly Bean Keyfinder.
The link to this software can be found here. Go to download the latest build on the right side of the page, then run the program. Hope this helps!
Dec 28, 2008 | Microsoft Windows XP Professional
Unable to access my disk with any operating system
Seems you got a broken down drive, you can try it on another computer to see if the issue persits or take it to a computer repair shop to get it tested, no not wallmart, some real computer repair place
Aug 29, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Hard disk partation not found
better to dump your data from main hard disk then once reformat your main hard disk then that external hard disk work properly .............
Feb 16, 2008 | Microsoft Windows XP Home Edition
Hdd data back
setup your operating system thru repair, how? install your winxp by pressing the repair instead of INSTALL NEW FRESH WINXP. in this way you can recover the corrupted parts of the operating system. don not reformat. i hope that this will help you and i am expecting a positive response from you.
Dec 04, 2007 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
