Question about Canon PowerShot S3 IS Digital Camera
The right function button on the Omni Selector has ceased to function. All other i.e. up, down & left is functioning properly
  • 4,472 Answers
Your best option is to have the camera repaired by an an authorized service center. You can start the repair process here:
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_s_series/powershot_s3_is?pageKeyCode=requestRepair
Thank you and good luck,
Lee
Posted on Aug 03, 2010
Recently purchased spyder towing mirrors for my 2008 chevy silverado hd. After installing the mirrors will not move left or right (both sides). They will move up and down and the heat will also function....
Did you connect them correctly? which model of spider towing mirror did you purchase?
if your vehicle originally has only a left/right function then probably you connected it to the uptown function of the mirror. If your vehicle provides up/down & left/right function then I would check the wiring.
Dec 16, 2017 | 07-12 Chevy Silverado / Sierra Heated...
The LEFT KEY on my mouse is doing the functions of the RIGHT KEY (the drop down window) and the RIGHT KEY is doing the
Try going into the Control Panel and navigate to mouse properties. There is an option there to reverse the button functions.
Dec 20, 2011 | HP Computers & Internet
HELLO, I HAVE A AUDIOVOX #CD198. THE RADIO WORKS BUT WHEN I MOVED THE FUNCTION BUTTON ALL THE WAY TO THE RIGHT TO LISTEN TO CDS ALL I HEAR IS THE CD TURN BUT NO MUSIC AND THE SAME THING HAPPENS WHEN I...
hi,if the function selector of your audiovox is an manual selector switch you need to clean the contacts of it by spraying it with a contact cleaner (windex) spray the cleaner directly to the contact of switch then rotate the switch repeatedly until contact is clean be sure to unplug the unit before applying the cleaner.you need to open the cover of your machine to be able to access the function switch..good luck!
Jun 30, 2011 | Audio Players & Recorders
How can I set the date?
Press the HOME button to get the main menu. Touch the wrench-and-screwdriver function area to enter the Setup menu. Touch the down-arrow function area until you see the "Date" option. Touch the calendar icon function area to enter the Date menu. Touch the left-arrow function area to select "Set date." Touch the left/right-arrow function areas to select the digit, the up/down-arrow function areas to change. Press the Menu/OK button to confirm the changes.
Aug 12, 2010 | Vivitar ViviCam 8025 Digital Camera
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
Jul 20, 2009 | Canon PowerShot SD870 IS Digital Camera
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
thank u!!!!
May 26, 2009 | Canon IXUS i7 Digital Camera
Green button sticking
I have that problem a lot with this model. Unless it's 'sticking' which would mean its dirty... this in my opinion needs to be repaired. That is what i always do in this case.
May 14, 2009 | VeriFone Omni 3700
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Setting time
1) Make sure that all CDs are out.
2) Hold down SRC button until radio turns off.
3) Hold the function button down until the clock appears with the hour flashing.
4) Press the left or right arrow to select the hours/minutes.
5) Press the up or down arrow to select the time.
6) When time is chosen, press the function button again to set.
Apr 01, 2008 | Pioneer DEH-P3700MP CD Player
Canon PowerShot S3 IS Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
