Question about GE Refrigerators
Ge model tfx22z it runs all the time but the frezzer and food department are normal temp
  • 166 Answers
It is normal for a refrigerator to run 75 per cent of the time or more depending on the temperature of your room. Very hot weather and a lot of door opening can cause a refrigerator to run more. as long as everything is freezing and cooling, i wouldn't worry too much.
Here are several things you could check. first clean out the condenser coils underneath the refrigerator. check to see what your thermostat is set on. set it to 5 (normal). You can also slowly turn it down toward the lowest number and see if the compressor kicks off (this will let you know the thermostat is working). you can also check your door gaskets to make sure everything is sealing good around the doors.
Posted on Aug 03, 2010
Testimonial: "I TRIED TURNING DOWN THE THERMOSTAT AND IT STILL KEPT RUNNING THE ONLY WAY TO STOP THE RUNNING IS TO SHUT IT OFF"
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
What temp should the frezzer be and what temp should fresh food side be
hello, the standard temps are zero in the freezer and 38 in the fresh food side. Hope this helps.
Jun 07, 2011 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
I have a ge refrigerator MODEL NUMBER GTS18FBSARWW AND THE FREEZER IS NOT COOLING completely
i have a ge fridge and the frezzer is working, but the fridge isnt keep food cold enough
Dec 28, 2010 | Refrigerators
Ge fridge getting warm
DEFROST CYCLE LASTS FOR 20--30 MINS.AND TEMPS WILL REACH WHAT YOUR READING FOR A SHORT PERIOD OF TIME BUT NOT LONG ENOUGH FOR FOOD TO START TO DEFROST .HOPE THIS HELPS.PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | GE Refrigerators
I just has the motherboard replace last week and now the Refrigerator side stop working and I have Ice on the back wall of the frezzer . Frezzer is still working well. gss22wgmd
You don't say why the mother board was replaced. Make sure the board was the correct one, part number WR55X10656 for your GSS22WGMD and that all plugs are firmly and correctly attached to it. If yes, then check the defrost heater (located behind the back wall inside the freezer, near the bottom) to see if it is burnt out. (If you disconnect the wires from each end of it and test, finding no continuity, it is bad) It is a part number WR51X10101 for your model, and is a fairly common failure point. While you have that apart, manually defrost the coils with a hair dryer. (the manual defrosting alone will get your refrig working for at least a week, allowing you time to get any needed parts.) If left alone without defrosting, your freezer section will not be working well soon either.
Jul 29, 2009 | Refrigerators
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
GE fridge GDS 18 LBR
Have u check the moisture control in the frezzer? If so make sure that all the vents are clear of all food and/or food containers and such... Turn ur fridge temp control to max.. Wait 5 hours WITHOUT opening fridge or freezer. Good luck! Let me know how everything tur out
Nov 10, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Refrigerators Logo
160 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
