Flashing auto display - won't power up
I have a JVC HR S5400U VCR. Display flashes "auto" and unit will not respond to any buttons on VCR or remote. Inserting tape powers up unit only long enough to accept cassette. Manually pushing on cassette inside unit will cause unit to power on only long enough to eject cassette. I have already unplugged unit for several hours and tried holding down the power button on VCR and remote for 10 seconds, but no change. Thanks in advance for your help!
  • shermankat Apr 27, 2008
    I have the same problem except a tape is stuck.  But the unit is flashing Auto and the power will not stay on.  Any ideas???
  • Anonymous Jan 21, 2009
    I have a toshiba VCR that is not responding to anything. It is just flashing AUTO. AHH..I need help
    Problem Solver:
  • 8 Answers
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
Posted on Apr 28, 2008
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Posted on Mar 11, 2009
Lightning damage
Replace the parts with the original ones, a .5 ohm difference on a resistor on the video circuits will cause the unit not to work correctly.
Sep 27, 2008 | JVC HR-XVC27U DVD Player/VCR
Remote not responding
Are you holding enter and channel number at the same time for about 2-5 seconds
Aug 05, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
I had d problem where mi dvd was unable 2 eject cuz it was locked, so i uplugged it den pluggd it bak n held d power button and it suddenli went off as i was holdin d button n now it doesnt wanna ***...
Normally when the VCR is plugged in, the display should blink. If not, it could be broken. Since I am not sure about this model, do an experiment. Unplug the unit. Wait for a few minutes. Plug it back in and insert a video cassette. If it powers up and the display turns on, VCR should be OK. The unit may be reset to factory default and the remote might be set to different code. The remote can be reset to factory setting by removing the battery for a few minutes.
Feb 18, 2009 | JVC HR-XVC19S DVD Player/VCR
JVC HR-XVC37U Combo problem
You have the child lock (CL) turned on.
Your instruction manual will have the information about turning it on or off.
It's purely t prevent small fingers doing bad things to expensive electrical equipment. =)
If you cannot locate the info in the manual, post back and I will hnt the relevant info for you.
Apr 29, 2008 | JVC HR-XVC37U DVD Player / VCR Combo
Unit won't turn on, goes into standby, flashing "auto"
The mechanism is not "shutting" when power is applied. This step is necessary for the unit to operate. Would suggest a complete belt replacement and cleaning....accordianman
Apr 26, 2008 | JVC HR-S9500 S-VHS VCR
Instruction Manual JVC HR-J425
You need the remote working to get at the on-screen setup menus. make sure the remote is set for the VCR (VCR button) and try the menu button. Are you sure this is the right remote for the VCR. May have to get a new remote. Make sure it is a universal that has a MENU button.
Dec 24, 2007 | Televison & Video
JVC HR-S9500U
OK, found the problem. Another website had the same question on the HR-S9600U, the 9500's replacement:
http://www.cippico.com/bbs/viewtopic.php?p=528&sid=ce3dfc944e4539181195720b836021f4
I checked my vcr, and, sure enough, there was a sort of clicking sound coming from the drum area immediately before the unit would go into "Auto" mode. I removed the complete drum assembly, and tore into the little gearbox, and found the two black, plastic gears with inside pinions that drive the metal screws to change the video head position had each cracked and were slipping on the shafts. This caused the gearbox to bind up.
Using a jeweler's screwdriver, I roughed up the metal shaft and the inside of the gears where they slip onto the shafts, and glued them on using a two-part epoxy. I then re-assembled it all, sorta setting the screws about two turns after their contact with the base of the upper drum. Now, upon power-up, the drum adjusting motor toggles one direction, then the other, and the unit stays on. Playback seems OK.
So, there you go. Yay me....
Oct 19, 2006 | JVC HR-S9500 S-VHS VCR
Televison & Video Logo
637 people viewed this question
Top Televison & Video Experts
