Question about Intex Frame Set 12 ft x 30 in Pool with Pump
How do you change the filter on an above ground pool pump?
5 Suggested Answers
  • 77 Answers
SOURCE: Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Posted on Apr 28, 2009
  • 77 Answers
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
john224
  • 1378 Answers
SOURCE: How to refill the Hayward s200 sand filter for
Fill the empty and cleaned tank about half way with water, cover the stand pipe in the filter with a plastic cup or some other means to ensure sand will not go down the pipe. Be sure the pipe is centered in the hole. Add 200# of #20 silica sand and once filled use your hand to reach in a level off the top as best you can. The sand will be about half way up the filter and now the water will be near or over the top. Once done, secure the valve in place and connect the hoses and you are ready to go.
Posted on May 18, 2010
Can I use this in an above ground pool
in ground or above ground the only difference is the plumbing to and from the above ground pool
place the pump and filter well away from the pool and use imagination and pvc pipes to plumb it in.
May 22, 2015 | Pool & Spa
Above ground pool how to get and keep crystal clean water
If you clean your filter frequently, and keep your chlorine level to at least 5.0ppm it will help but with "out of the box" above ground pools the filter is really undersized. Check to see if a larger filter or pump can be installed on your pool. Also because it is an above ground pool if the temp gets above 84 degrees the chlorine dissipates rapidly, you can switch to Bromine which dissipates at around 104 degrees and provides the same sanitation levels as chlorine.
Jul 15, 2014 | Pool & Spa
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
I have a proline de 1.5 hp above ground pool filter. How much de do I put in the filter? Thanks
one pound of D.E. for every 10 square feet of filter area, there should be a data plate on the filter telling you what the filter area is.
Jul 30, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
Im just wandering if I can use a Bestway filter pump on any pool?
Depends on the size of the pool, is it above ground or in-ground, Typically above ground pools use a 1/2 hp pump an in-grounds use 1 hp or more, spas use even higher. Hope this helps.
Nov 26, 2010 | Pool & Spa
SAND IN ABOVE GROUND POOL
First, the vacuum should easily pick up sand if the pump is working properly. The sand in pool may be coming through a cracked or broken lateral. If you changed the sand recently and did not prefill the tank with water, then this could be the reason. Plastic parts do fail eventually. Be sure that you perform the rinse cycle aftewr backwashing to settle the sand bed. Instructions on filter tank.
Aug 12, 2009 | Hayward Pro Series 18" Above Ground Pool...
Sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
How i change the filter on my intex pool
Unsrew 'white' knob on top of filter box.
Remove paper filter - clean or replace.
(use garden hose and blast filter clean)
Jul 06, 2009 | Intex Above Ground Pool 530 gal/hr Water...
Sand in backwash
You need to replace the seal in the head unit of the filter.. The sand should be replaced every three years or buy a cleaning solution.
Jun 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
Intex Frame Set 12 ft x 30 in Pool with Pump Logo
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
