Question about Sport & Outdoor - Others
I have a TX500, never been used (just out of the box) and had to get an electrician to my home for this problem. It will start rolling but quits in a few seconds. The electrician believes that it is a problem in the sensor that rides at the belt. There is only one sensor in the pulley; he thinks that perhaps there should be two as there is a hole placement opposite the one that is in there. When the belt quits, it goes to a number 3 on the board which he thinks is the sensor as well. If he is correct, where do we get another magnet to place there? If he is not correct, please offer help. We did not get a owners manual in the box and surely could use one; where can we get one? Please help...thankyou
    Genius:
  • 1,478 Answers
I believe the best thing to do at this point is to look for a way to get the manual of the device, this will give a full guide and better understanding on how to fix this problem.
Check maualnguide.com to search for the manual of the device, the link provides almost all manuals to all device.
Take care.
Posted on Aug 03, 2010
Installation Manual for TX500
Hi Kathy Cox,
You can access the User Manual for your TX500, at this link:
http://bit.ly/1sCM4uU .
Regards,
Gaby
Motorola Mobility
Oct 12, 2014 | Motorola Mobility TX500 89494N Bluetooth...
Motorola tx500 speakerphone
Jean-
The device cannot be self repaired. CONTACT US
Mark
Motorola Support
Apr 07, 2014 | Motorola Mobility Tx500 Bluetooth Car Kit...
Motorola tx500
Jean
Unfortunately we don't provide this kind of instruction. Have you CONTACT US
mark Motorola support
Apr 07, 2014 | Motorola Mobility 89494n Tx500 Universal...
Both windows will not roll down, dome lights quit working,keyless entry quit working. All these things quit at once
check your dome light fuse, many mfg.s will use dome light fuse for security systems too.fuse box should be at kick panel.
Dec 31, 2009 | 2001 Volkswagen Beetle
My 1990 Ford F-150 suddenly quit running
Look under the dash, against the firewall. there is a little box. on the top of this box is a little button press the button for 10 seconds with the vehicle in the on position but not running position. That was the problem on my 1991 f-150, it is the first inertia switch. It is a safety shutoff incase the vehicle is in an accident or rolls, but a simple hit by the foot can trigger it.
Jun 15, 2009 | 1990 Ford F150
1974 TX500, high idle, white smoke from breather tube
The idle problem is a lean fuel mix caused by an air leak in the intake system. Bad gaskets /seals on the intake manifold, bad valves, bad piston rings, loose spark plugs, and bad head gasket are all things that can lean the fuel/air mix. The smoke indicates a need for new rings. I would have the cylinders bored then install new pistons and rings. Now finish the top end work by getting a valve job. You should get a liquid fuel tank liner to eliminate any rust problems in the future. Also, install an in-line fuel filter. Google “ kreem fuel tank liner “ or go to www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html
My complements on the well cleaned carbs. Do the work mentioned above an you will effectively have a new engine.
A “very helpful” rating for this answer? Thanks!
Jun 11, 2009 | 1973 Yamaha TX 650
74' TX500, High idle and White smoke from breather tube
When the carb was rebuilt it was only bench tuned. It is always wise to tune them once installed. the smoke may stop after the carbs are adjusted. However white or light colored smoke is always an indication of oil. It sounds like you may have a small leak. Hope this helps. Good luck.
Jun 11, 2009 | 2003 Yamaha YZ 250 F
I have a home built in the 50's. circuit breakers are pushmatic. 7 breakers on a side. The locking bar down the center will not allow me to replace 2 single pole breakers with double pole. It's for an...
You need to put in what we call a sub box. This should be done by a licensed electrician, but if you really want to do it yourself you will need a distribution box some wire and it has to be connected directly to your main lags from the meter box, this box will have a main breaker built into it and spaces for additional breakers, depending on your existing wiring the electrician might chose to wire the additional box directly to your meter base and not your existing box. Either way you really should seek local professional help on this project, just for your safety and to satisfy your home-owners insurance.
Have a great day..
Tim
Mar 06, 2009 | Connecticut Electric & SWITCH UBIP130...
Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
Dec 13, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Sport & Outdoor - Others Logo
23 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
