Question about Dishwashers
Fisher Pykel draw dishwasher has F1 on both draws
  • gibsongarry Nov 19, 2008
    f1 on both drawers and shuts off and on with the f1 displayed
My fihser dishwasher is showing f2 and not draining
Posted on Apr 28, 2010
Need to remove upper drawer Fisher and Pykel dd605ss
Open the top draw. On each side of the draw at the bottom / front, is a clip that releases the rails that the draw slides in and out on. Press the clips in to release and slide it back (into the machine as if you were closing the draw). Do this one at a time and then lift the draw slightly and rotate the draw anti-clockwise direction (due to the plumbing) and lay the draw on its left hand side. The draw is out!
Oct 18, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a single draw Fisher and Paykel dishwasher. I stupidly put washing up liquid in the dishwasher which resulted in a F1 problem. Water started leaking under the draw and onto my floor. I turned the...
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Apr 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My fisher paykel top draw does not close fully and therefore when it operates its floodsa nd the f1 code comes on. I know how to clean and reset it but not sure why the door will not close fully, I can...
check the draw on the sides at the front as the draw sits on runners and there are tabs on the runners at the front which hold the draw on. hold the plastic tabs both sides and slide the draw past the slots on the bottom sides of the draw.
Jul 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
HI I HAVE A F2 CODE ON MY TOP DRAW OF MY DELONGHI DOUBLE DRAW
You will need.to remove the draws and dry the under tray as it has a flood.warning sensor to detect water, this is due to lime.building up.around the tub top.seal and will.need.cleaning off as it causes leaks to run down into the tray
May 12, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Dishwashers Logo
250 people viewed this question
Top Dishwashers Experts
