Question about HP ScanJet 4500C Flatbed Scanner
When try to scan, lamp warms up then message received is scanner could not scan. 22 is NOT blinking. The scanning mechanism begins move across the page but only moves about half inch.
    Problem Solver:
  • 19 Answers
The scanner may have one of two problems:
1. Scanner lamp has failed or does not come up to full color temp
2. Scanner attempts to initialize, which means it must move a bit to what is the "home" position where the scanner actually reads a very small coded imprint on the underside of the glass. If this area is too dusty or dirty, that will cause this problem, but also if the scanner motor and worm drive are binding for any reason, such as the scan rails internally being too dry this will also happen.
Locate a service manual and remove the copy glass by removing the lock guide on one side, the glass should lift partially, allowing some gentle cleaning with soft cloth and glass cleaner. Do not attempt to force the scanner to move inside, as it is worm gear driven and such an attempt will strip the nylon gears or worse.
Follow the manual instructions if you need to fully remove the top
cover, glass and platen assembly for cleaning. It is very simple once you are in the interior...but gentleness and care are necessary.
Sadly, parts are difficult to find for all scanners now, and it is often far more economical to replace with a new, low cost and higher performing, higher rez unit for $ 120 or less. Often a lot less.
Good Luck!
Posted on Aug 04, 2010
Error 22
Go to hp website and look for firmware update. The model M1217 had the same issue which was fix in a firmware update.
Jun 07, 2012 | HP LaserJet Pro M1212nf MFP -...
I have umax 4700 scanner. When I tried to scan something it shows "scanner lamp has not warm up yet" & keep counting upto 30 seconds. It will take 4 to five time this exercise than it's ready...
hi rakyansfi,
Is that scanner old?because lamp has its own life span.
it cannot scan if the lamp is insufficient power or light.
regards,
mastergani
Dec 30, 2010 | Umax Astra 6700 Flatbed Scanner
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Can't scan scanner gets stuck
Hi, you just reinstall the scanner software and then try.
OR
If your scanner in the warranty then replace it because this is the major problem in the flatbed scanner.
May 24, 2009 | HP Scanjet 4470c Flatbed Scanner
Scanner Canon 3200F using ScanGear CS software at some stage decided to show this fault: Cannot scan for these reasons: - The Original may no be set correctly - The Film Adaptor Unit Protective Sheet...
The problem went away for me, when I reset the error message on my MP830. In this case, the message was that I was out of ink. Not a problem for scanning, yet this gave me the "lamp" message. Reset the message by pressing the "OK" button.
Jul 06, 2008 | Office Equipment & Supplies
Black area above the scanned image.
If you set Automatic brightness/Contrast this happens. Try manual setting. Adjust different settings and select the best suited for a particular type of drawing. The scanner takes couple of milliseconds to judge the best lighting, by then the paper has moved little. This area appears black. This is easily solvable.
S. Mohan, Chennai, India
Dec 06, 2007 | Canon DR-9080C Path-Through Scanner
ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Aug 16, 2007 | AcerScan 620PT Flatbed Scanner
Canoscan Won't Scan
You have to reinstall drivers of your scanner. Thank you.
Aug 11, 2007 | Canon CanoScan 8400F Flatbed Scanner
HP ScanJet 4500C Flatbed Scanner Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
